Loader Adding bucket grapple to 1533 MF
   / Adding bucket grapple to 1533 MF #1
moretzb
Patterson, NC
Massey Ferguson1533 / Ford 1310 / Farmall cub / 1946 Farmall B / 1942 Farmall M
I am looking at building a bucket grapple for my MF 1533. The dealer claims there is no where to hook up the hydraulic controls. Does anyone have any advice / experience ? Thanks !
   / Adding bucket grapple to 1533 MF #2
W.R. Long ,for a kit for your tractor.You have to add a valve and controls.
Thanks ! I shot them a email.
   / Adding bucket grapple to 1533 MF #5
There are tons of threads about the electric hydraulic third function kits on TBN. W.R. Long works through Dealer network... so you'll have to go through a dealer to get it.
   / Adding bucket grapple to 1533 MF #6
We've got a WR Long 4n1 on our MF 1533 with Elec/hydraulic (at least that's what I think it is) on it and love it.
Cool Thanks for the input. I have a rhino also. For work and for fun !
TEG, I looked at your posts on adding the hyd controls. That sounds like something I can do and save a little $$
   / Adding bucket grapple to 1533 MF #9
With help that you can get from TBN... heck you can build a whole tractor!!!! :D
The W.R. Long kit is expensive for one connection but many people love to be able to press a button with the thumb and never let the hand move off the one joy stick. If I only needed one function... I would think hard about that one. It's pretty easy to install compared to what I did.
I wanted 3 spools for 2 more hydraulics out back for hydraulic top and side links so the route I went was (somewhat) cheaper but it is not a KIT. You have to plan and it a longer "thought out" process... trying to figure out what you need and most likely a couple mail orders later...
Is this your tractor...
TractorData.com Massey Ferguson 1533 tractor information
Main thing there, is you're an "Open Center" and your flow is "9.1 gpm" mine was 6.2-ish and could use the 8 gpm max where you would have to step up to the next size.
Plan to read lots of threads about hydraulics... and when you get to the point where you think ;) you know what you are doing, post questions in the hydraulic section. The power of the hydraulic pump goes from one thing to the next, each able to use the power as long as what's up stream is not using the power. I put my spool after the FEL but before the 3ph.
The location of the spool/valves is one of the first things you need to figure out. I mainly located my spools mid way mainly because I didn't want to clutter up or block the view of the three point hitch. We're called "compact" tractors for a reason.
Thanks for the info. That is my tractor. I will check into the hyd section of TBN for sure. I have not been there yet.
2013 FORD F150 XL TRUCK (A51243)
2013 FORD F150 XL...
THE ROOTSTER STUMP & ROOT PICKER (A51243)
THE ROOTSTER STUMP...
2016 Nissan Altima Sedan (A50324)
2016 Nissan Altima...
2011 CATERPILLAR 303.5 D CR EXCAVATOR (A51242)
2011 CATERPILLAR...
BE Quick Attach Snow Blade (A50514)
BE Quick Attach...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
