Adding another ( 2 total ) 60 inch deck to my 755 , Looking for suggestions
   / Adding another ( 2 total ) 60 inch deck to my 755 , Looking for suggestions #1
Kevin M
goshen NY
48" bobcat walk behind , 60" Dixie Chopper Classic , 755 John Deere 4x4 70 ldr belly mower etc etc , 7610 Ford 4x4 7412 ldr and 10 ft rhino hogg
I currently have a single 60 " inch belly mower on my 755, I found what appears to be another one. So what I want to do is stagger the 2nd off to the right side behind the tractor to increase the mowing width. The mower under the tractor runs at 2000 rpm , The rear PTO runs at 540. Question # 1 , Do I have enough power to spin both decks, even if I increase the rear PTO by speeding it up through pulleys or do I need another motor to power deck # 2. Question # 2 has anyone else done this successfully ? I would like to be able to lift and lower the 2nd deck hydraulicley like a wing for easy storage.
P.S. I already have an extra valve plumbed , So the hydraulics is no problem.
   / Adding another ( 2 total ) 60 inch deck to my 755 , Looking for suggestions #3
What I did was to ditch the belly mower and went with an 84" rear finish mower. Plenty of power for that.
Make a trade. Only advantage to me for a MMM was the ability to add a leaf vac. Sooo, I boughr a diesel front mower. Best of all worlds.
   / Adding another ( 2 total ) 60 inch deck to my 755 , Looking for suggestions #4
Sounds like a really challenging project, if you follow through with it. I think you may wind up spending a lot of time working out all the problems that the design would create as opposed to actually using it, let alone the cost for the deck and whatever parts (and manhours) needed to make it all happen. You could make it a self powered tow behind unit that was offset with a long, angled tongue but in that fashion I don't think it could be raised like a batwing mower.
Me personally, I think I would do like zzvy suggested and get a wider RFM and go with that. The reason I say that is because after all that work, you might gain maybe about another 2 1/2 ft of cutting width beyond what you can already cut. I think you will only be able to offset the second deck just so much (if you go with attaching it to the tractor's 3pt). That is, unless you have some really radical design in mind that lets you offset it so the cutting edges just barely overlap. Good luck with it.
   / Adding another ( 2 total ) 60 inch deck to my 755 , Looking for suggestions #5
Hi KevinM,
Looks like what you are trying to do already exists. I would not be surprised if it was all from JD but the thread says the mounting bracket was made by a different company.
http://www.tractorbynet.com/forums/attachments/176364-help-identifying-offset-mower.html
   / Adding another ( 2 total ) 60 inch deck to my 755 , Looking for suggestions #6
The link DSMAU posted has a cool idea; but I'd want some counterweight on the right side regardless of how it attaches to the tractor.
I don't know what the HP of your 755 is; but somehow I suspect you're going to have trouble powering both decks with the tractor alone.
   / Adding another ( 2 total ) 60 inch deck to my 755 , Looking for suggestions #7
there be a few threads i have came across in last couple months for "off set" mowers to help make a wider mowing path.
myself have also looked into this. for me it came down to either paying for a 3pt bat wing finishing mower. ((2 or 3 decks, with 3 blades per deck)) or going with a "gang reel mower"
a gang reel mower, seemed like best option for me, and would give a better cut and followed the hilly terrian i have much better. vs a finishing mower wider decks that would end up scalping and cutting into dirt more often.
also once i got into the larger bat wing style finishing mowers. the HP required for tractor went up rather fast, vs "gang reel mowers" that require a lot less HP to pull and use them.
other words to above....
wider finishing mower deck always quickly sounds nice. until ya get into hill terrian. then once you realize how much scalping you are doing. and how much extra care you have to take. wider finishing mower decks quickly go by by. and then multi smaller decks come into play.
if you had pure flat land say like a golf course a single wider mowing deck might be awesome on another hand.
with multi smaller decks, come added cost of hyd lift for bat wing style mower decks. and then the old neck / back pain of twisting around constantly to see how things are as you mow. due to needing to be on rear of tractor.
off set mower can be nice. i tend to see ""ATV"" finishing mower decks with pretty simple way to off set them. and a gas engine on them. but normally in this situation it is just a single mowing deck being pulled.
some additional things to think about. i tend to see more threads here on TBN about folks cutting seat time down by a good amount with a commercial grade Zero turn mower ((not a cheap small city yard zero turn mower, but a beefer zero turn mower)) due to ability to make quicker / easier turns. and applying power were it needs it. and being able to see were you are mowing. they are all small little things. but when you make 100's of turns and mow around multi things it all adds up.
on other hand if you are a tinker and like pulling stuff apart and putting it back together and building things, and ya have the tools and know how. i would say go for it. could be a very fun project. and work great for you.
i just know for me. while i like to do above, not enough time for this type of project. and if i had the cash i would sink it into "gang reel mowers" if not a bat wing rear finishing mower. if not a larger commercial grade like zero turn mower.
if it was a zero turn mower, then, for me it would be automatic to have a tractor as well. having 2 machines can be handy, and can mean getting R4's or R1 tires on tractor, while leaving turf tires on the zero turn. so you do not tear up the grass as much.
i hate to say it, but with finishing mowers, if the grass is a little bit to wet or a little bit to tall. it can quickly cause me to change to lower gears and set a higher throttle speed. to keep cutting the same width. and things can get to a point were i need to start taking "half cuts" vs full deck widths of mowing. if you don't have that much problem with what you have now with what you have to mow. an additional off-set mower might be just right for ya.
   / Adding another ( 2 total ) 60 inch deck to my 755 , Looking for suggestions #8
some additional food for thought. if primary wanting is to help get into ditchs to mow. or perhaps taller grass / weeds. for wanting a rear off set mower. you might be better off looking at a "3pt sickle bar mower" or a pull behind pto sickle mower.
A 755 is 21/22 hp at the flywheel, 15/16 at the PTO. The tractor is set up to run front or rear PTO or both. Why wouldn't they want you to run both PTO's if they JD set it up that way ?
A 755 is 21/22 hp at the flywheel, 15/16 at the PTO. The tractor is set up to run front or rear PTO or both. Why wouldn't they want you to run both PTO's if they JD set it up that way ? PS yes I already have a 60 inch Dixie Chopper with 27 hp , But I can't run both machines at once and I thought this might work to cover more area.
ECONOLINE TRAILER, INC (A50323)
ECONOLINE TRAILER...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2 windsor 351 inboard motors w/transmissions shafts rutters and props (A53424)
2 windsor 351...
2012 JOHN DERE 310K BACKHOE (A51406)
2012 JOHN DERE...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
