3-Point Hitch Adding A Three Point Fork Lift
   / Adding A Three Point Fork Lift #1
shawn_m_ferrell
Hi All,
I have a procured a three point hydraulic forklift that I am now trying to "plumb" into my Ford 1715 which has a front end loader. The forklift only has one hose (to both raise and lower as down force is provided by the load on the lift) and I have no clue how to connect it.
I don't need to use the FEL when using the forklift so I could use one of those valves if needed.
If anyone has done this before please fire back how.
If not, I'll post pictures, diagrams, etc looking for some help engineering a solution here or in the hydraulics forum.
Thanks in advance,
SF
   / Adding A Three Point Fork Lift #2
I used to work on forklifts, they are a single acting spool valve, they have a flow control valve on the bottom of the mast to control the downward rate of the forks.
Craig Clayton
   / Adding A Three Point Fork Lift #3
:welcome:
Run one of the lines to the bucket curl (I'd think the 'curl down' line) back to the single cylinder and I think that should work good for you.
Cummins Power Generation 35GGFD-3301 (A47384)
Cummins Power...
2023 JOHN DEERE 333G SKID STEER (A51242)
2023 JOHN DEERE...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
2014 International Pro Star Semi (A50514)
2014 International...
2006 Volvo VNL (A52748)
2006 Volvo VNL...
2017 E-Z Beever M12R Towable Brush Chipper (A51691)
2017 E-Z Beever...
