Front-End Loader Adding a snowblade to a FEL
   / Adding a snowblade to a FEL #1
72chevy4x4
Bronze Member
John Deere 3038e
I bet someone has gone down the road I'm am pondering...getting ready to purchase a B7800hst w/ a 402 (I think) FEL. Going to purchase the ATI Quick Attach system and then modify the stock bucket w/ a QA plate. The reason for all of this is to mount a snowplow. The big question is how can I operate the plow cylinders (the bucket will be off)? I had considered mounting an additional hydraulic valve next within reach and an additional set of hydraulic lines down the arm of the FEL w/ connections at the end.
I just got done reading a post regarding 3posn and 4posn loader valves. It seems as if we can order a 3 or 4 posn valve w/ the new B series tractor (is that true?). Will the 4 posn valve enable us to control the plow cylinders-if so, how? Does the hydraulics to the dump function get bypassed or disconnected? I'm imagining the plow angle turning as the angle of the QA plate turns too-that can't be right???
Thanks for the feedback guys-I've already picked up a great deal of info from reading the last few days!
   / Adding a snowblade to a FEL #2
I found it easier to add a 3rd valve to my tractor. You want a 4 way valve regardless of which tractor/FEL you buy.
In the other thread on Quick coupler you will see my FEL blade setup.
   / Adding a snowblade to a FEL #3
72,
This has been discussed here on TBN alot!
Do a search on "FEL plow" and "FEL snowplow" to see lots of homemade solutions!
Here is a link to the one I made:
http://www.tractorbynet.com/forums/build-yourself/49283-fel-snowplow.html
Now, as for the angle, again do a search for "electric diverter" and "diverter" to selots of options and opinions on this. It will cost about $500 to add a hydraulic circuit no matter with way you go...
Here is a link to the thread on my diverter install:
http://www.tractorbynet.com/forums/customization/48310-added-remote-fel.html
Hope this helps some!
2012 Nissan Rogue SUV (A50324)
2012 Nissan Rogue...
Case IH 1250 Grinder Mixer (A50515)
Case IH 1250...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
2025 GIYI GY-X380 Trencher Mini Skid Steer Attachment (A50322)
2025 GIYI GY-X380...
2023 TAKEUCHI TB370 EXCAVATOR (A51242)
2023 TAKEUCHI...
2018 FORD F-150 (A52472)
2018 FORD F-150...
