adding a loader to a L3010
   / adding a loader to a L3010 #1
double hunter
Ford 1715
Im looking at buying a Kubota L3010 4wd,,I have a Koyker loader that will fit on this,,what I need to know is the L3010 plumbed for a loader or will I have to add the control block,,any help greatly appreciated,,I cannot look at it,,it is several hrs away
   / adding a loader to a L3010 #2
Can they not provide photos for you to look at? Do you have an ad that you can show us?
Where is the tractor located? (maybe a member here might be able to help)
A whole bunch of tractor scams start with the tractor being bought is too far away to view before wiring money (or sending money)... I would really worry that it's a scam if they say that "they" will ship it to you. BIG RED FLAG!!!
   / adding a loader to a L3010 #3
When I ordered my new L3010 4wd HST, it arrived at the dealer with a H23502 hydraulic outlet block already installed.
Kubota L3:)DT / GST / HST Parts Diagrams
The dealer used the block to connect the OEM LA481 FEL.
If your L3010 is a GST type, the part number for the hydraulic block is H23501
Kubota L3:)DT / GST / HST (4wd) Parts Diagrams
It isn't certain the L3010 you are looking at is equipped with either of these blocks however and they may or may not work with your Koyker FEL. The block assembly's go for around $650. Perhaps you could send the parts diagram to the seller and ask him to take a took. The block is located on the right side of the tractor transmission midway between the front and rear tires.
I would post pictures but I traded the L3010 several years ago.
Manac Walking Floor Trailer (A50322)
Manac Walking...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
2000 FORD F650 SINGLE AXLE DUMP TRUCK (A52472)
2000 FORD F650...
Miles read : 112,969 (A50323)
Miles read ...
3 POINT  7FT RAKE (A52472)
3 POINT 7FT RAKE...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
