Loader Adding a 2 spool valve
   / Adding a 2 spool valve #1
wykubotaguy
Bronze Member
Kubota L3400DT
Hello everyone. I am a newbie! Need advice on a new to me Kubota L3400DT w/LA463 FEL. I am wondering if it is possible to add double spool valve to the existing valve. Any advice would be appreciated. What i would like to add is a 3pt log splitter and a grapple fork in the future. Thanks again.
   / Adding a 2 spool valve #2
One question,
do you not already have two sets of rear remotes on the rear as standard equipment?
Most if not all splitters for tractors are used in the rear and mounted on the three point hitch; further the the rear remotes are "LIVE" all the time to allow operation of implements and pumps as well as feed grinders, manure spreaders with hydraulic controls, hydraulic powerered ground engaging implements like hay crimpers, tedders, balers, the hydraulic powered rototiller,
bedders, middle busters, the plow, subsoilers, etc........
The grapple attachment will simply use the spool that is controlling the bucket when installed
No good will come of what you want to create and plumb up on your tractor.
leonz
The tractor was bought second hand. I don't know if this model is available w/ rear remotes as the tractor does not have them and owners manual has no topic on them.
   / Adding a 2 spool valve #4
if yiu have a rear draft control you should have no issues putting in dual remotes.
thanks for the info leonz, but i got this tractor with 116 hrs on it and the guy who ordered it only got the FEL for an option. Any other choices?
   / Adding a 2 spool valve #6
Hello! Congrats on the new tractor! In fact, it sounds nearly brand new. That's a real good way to buy them.
Hmmm....My answer to your question is that it is usually easy to do. Here I have to admit that I don't know if the L3400DT has any specific unique details to its hydraulic system, but most tractors do not...JD is the exception in that some of their small tractors use a unique accumulator setup in what is known as a "closed hydraulic system". But most if not all Kubotas - including my M59 - use a far simpler "open circuit" system which makes it easy to add extra valves.
Here's how all open circuit system hydraulics work: The Gravity feeds hydrualic fluid into a positive displacement (that means gear or piston type) hydraulic pump which pushes it out through the hoses. There is minimal pressure and lots of volume of flow. Normally the hydrualic fluid flows right through the spool valve without any restriction. Without a restriction there is no pressure anywhere, only flow. When you move the lever the spool valve directs some portion of the flow to some secondar circuit which has a resistance like a bucket loader cylinder. There the flow is blocked by the cylinder and the blocked flow develops enough pressure to move the cylinder. That's tractor hydualics in a nutshell.
The important thing to take away from this is that your two spool valve could have been a five spool valve and would have worked five different items just as well as it does the two. It also means that all you have to do is to interrupt the flow to the existing spool valve and splice in an additional set of spool valves or several sets to get that capability. It is nothing more than simple plumbing. In fact, most spool valves have a fitting on the side known as a "power beyond" port which is there for this very reason. For additional spool valves you run a line from the PB port on one spool valve over to the inlet port on another set of spool valves and remember to allow each spool valve to have it's own free flow back to the hydraulic reservoir. That's it!
Here's where I confess that I'm not sure just where those ports are located on your L3400 but I think your question was just whether or not you could add them. Believe me, they will be there in your system somewhere and your dealer can point out the best place to hook them up. So the answer is yes, what you want to do is commonly done, it is easy and not too expensive if they do it and quite inexpensive if you do it yourself. I've done it on lots of tractors. Yes, it will give you complete control over the hydraulic flow to any attachment that works off a cylinder....things like a grabber, thumb, or log splitter. That's easy.
There are only a few attachments out there that use hydraulic motors instead of hydraulic cylinders; and powering them is a little different. But your tractor can be made to power those as well if you ever want to do that. It just takes a little more complexity and a little more money. But the tractor is certainly ready.
Enjoy! rScotty
   / Adding a 2 spool valve #7
Honest its just plumbing from the hydraluic system and if it has a rear draft control its no issue for a rear mounted splitter too; you simply want the best quick couplers which are spill proof and to make sure the male couplers are attached tot he tractor side to avoid issues of not having enough clearance on the mounting brackets which happened in my brothers case with his agco- as they were bad fittings to begin with.
The grapple is simply using the spool valve to close and open it-assuming its a gimballed valve on this unit too, the set up is no different with a spool valve. As rscotty has said its simpler and less expensive to let your local dealer do the installs for you as the two sets of rear remotes and quick couplers are all you need for the front hydraulics- BUT you will need to change the bucket each time you want to use the grapple.
   / Adding a 2 spool valve #8
I couldn't disagree more w/ this statement. Correct me if I'm wrong b/c I don't know if the L3400DT's hydraulic system is different than my L3400HST system, but for about 1/2 what my dealer wanted to charge for two rear remotes I installed my own 4 remotes. And I'm a tractor/hydraulic noob.
The thread is long, but you'll probably find some useful tidbits in this thread:
http://www.tractorbynet.com/forums/kubota-owning-operating/117710-l3400-ccm-hydraulic-top-link.html
   / Adding a 2 spool valve #9
I wanted to have the new higher quality hydraulic couplers
installed prior to the machines leaving the lot to eliminate
problems with faulty couplers and space limitations with
mounting the male ends on the remotes tro eliminate the
problems with mounting the female halfs of the quick couplers
on the tractor side of the plumbing and that issue period.:thumbsup:
Thanks for the info strangranger. I would like some more in depth pics and info on how to plumb in the spool valve(s). I am still trying to figure out what is the pb on the fel valve and so forth. Thanks wykubota guy
2003 PETERBILT 379 CRANE TRUCK (A45333)
2003 PETERBILT 379...
2014 UTILITY 53X102 DRY VAN TRAILER (A43004)
2014 UTILITY...
2016 FREIGHTLINER CASCADIA CA125SLP TANDEM AXLE SLEEPER TRUCK (A43004)
2016 FREIGHTLINER...
New/Unused 14ft Bi- Parting Iron Gate (Deer Design) (A44391)
New/Unused 14ft...
Pallet of irrigation Hoses (A44502)
Pallet of...
2010 TEXMEX GENERATOR TRAILER (A45046)
2010 TEXMEX...
