Adding 4th rear remote to 5085M
   / Adding 4th rear remote to 5085M #1
pclausen
Veteran Member
Nelson County, VA
JD 5085M, Ford 1700, JD GT235
So I got a 5085M on the way with the triple deluxe rear remotes, each of which will be controlled via the 3 levers within the red circle:
That will work great for various implements that I have, especially my 3-way hydraulic blade.
But I want to add a hydraulic top-link. Ideally, I'd like it to be EH like my hitch. So an OEM toggle switch in the blank shown in the yellow circle would be perfect for this. That would allow me to use the 3 regular levers for any normal implement hydraulic activity, and have permanent separate means of operating my top-link. That way I'll never be confused about which lever does to top link, as it will always be the toggle switch. The only time I would need to be remove the top-link and associated hoses would be when running my post hole auger.
Anyone done this, and if so, how/where did you tap into the hydraulics to pull it off?
   / Adding 4th rear remote to 5085M #2
Is your loader already 3 function? If not the third function kit (pricey, is a complete new loader valve) can route from mid body to the back pretty easily.
As a matter of fact it is! I'd just need to add hoses that are long enough to go from the top link to the 3rd mid valve. If I have quick disconnects on both ends, I can easily connect my grapple when needed, and also remove my top link for doing auger work.
Excellent suggestion!
   / Adding 4th rear remote to 5085M #4
It is a good idea... but (there's always a but) did you get the "mono-block" quick attach for the hydraulic couplers on the loader?
It looks like this:
If so; using quick disconnects will be a more "complicated" system - not so straight forward!
AKfish
   / Adding 4th rear remote to 5085M #5
Certainly can be done but there's gonna be some plumbing required...
AKfish
Yes, I believe that is what I got. It is option code 4556 "3-Function Single Point Hydraulic Connection". Here's another couple of pics from the H series brochure:
It looks a little different than the pic you posted. I think the brochure pic is from a much bigger loader/tractor. It is turned sideways compared to your picture. Which tractor/loader is that?
I guess once I get my tractor, I'll be able to take a closer look to determine what my options are.
   / Adding 4th rear remote to 5085M #7
That's a picture of my 5075M. Your brochure pics are basically the same option that I have on my 563SL loader. The 3rd function SCV is also a single point connection at the bucket as well. Locking lever, etc.
The brochure pics look like a 6000 maybe a 7000 machine.
AKfish
Excellent. I need to get me some of those color coded zip ties so that I can consistently hook up my rear implements to the same SCVs!
Like this right?
So my quick connects plug into the "block" and the "block" is the added/removed via that single lever, correct?
   / Adding 4th rear remote to 5085M #9
Like this right?
Yes and no... You could use quick disconnects on the block or you could plumb the hydraulic lines to the block and the block would stay with the grapple.
Since I have SS quick disconnects on my grapple - I did what you're suggesting - mounted the SS quick disconnects on the block. The block stays "locked" on the female mount (lever) on the loader whenever I think I might use the grapple.
I remove the SS coupler block most of the time as it is pretty vulnerable to damage.
AKfish
   / Adding 4th rear remote to 5085M #10
John Deere used to call this a MultiCoupler. I think made by Faster. I wish my 640 loader had one instead of six separate couplers, but too pricey to retro fit.
The third function hoses are marked green and yellow. They are in the middle of the multicoupler. I would swap hoses to get them to the outside of the multicoupler. Then below the the multicoupler (between valve and tractor half of multicoupler) I would install a pair of quick couplers (in the third function hoses). When you want to use the third function at the rear, disconnect and connect hoses from the rear to the hoses from the third function valve.
You can get colored tie wraps from Grainger.
2016 FORD F-450 9FT SINGLE AXLE DUMP BODY (A51222)
2016 FORD F-450...
2008 FORD F-750(INOPERABLE) (A50854)
2008 FORD...
3 pt Aer-Way (A50514)
1995 FORD F-800 BOX TRUCK (A50854)
1995 FORD F-800...
NEVER USED FECON 74in Deck Mulcher FDM74 (A51039)
NEVER USED FECON...
GENERAC GP6500 GENERATOR (A50854)
GENERAC GP6500...
