add line to winch?
/ add line to winch? #1
GaryS
franklin park, pa
Kubota L3901 & LA525
I bought a small 12v winch from tractor supply co. The winch came with 50ft of steel cable.
I want to use the winch to pull some tree rounds out of a ravine. Ideally, I'd like to add 25-30' of line. Has anyone added line to an inexpensive winch?
Here's a link to the winch I bought.
/ add line to winch? #2
really not practical due to the drum size.
Best thing to do is to get a stand alone section of cable with loops. attach it to your item run out the winch cable to the end of the dead cable, winch in the drum cable, remove the dead cable, and pull the drum cable for a second pull.
/ add line to winch? #3
Generally the amount of line is the max for that spool. To much line and you can jump the spool or bury the line in the wraps then back spool and you will have kinks and weaken the cable. I would suggest getting the additional length you need in chain and using that to haul the rounds out. Just put hooks on either end of the chain
Doing the double pull will work for sure. Speeds not all that important, getting the wood out is. I suspected that it would be hard to splice more line onto the winch but it never hurts to ask.
Thanks for the suggestions & advice.
2007 John Deere 1790 Planter (A63111)
2007 John Deere...
UNUSED WOLVERINE RSB66-66" ROCK SCREENING BUCKET (A64281)
UNUSED WOLVERINE...
2014 Komatsu HM400-3 Offroad (A62679)
2014 Komatsu...
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A58375)
2007 FORD F750 XLT...
2001 Freightliner FLD120 T/A Sleeper Cab Truck Tractor (A61573)
2001 Freightliner...
JCB 92" Clamshell Bucket (A64119)
JCB 92" Clamshell...
