Add a rear remote on a jd 3320
   / Add a rear remote on a jd 3320 #1
sparker133
Green bay, Wi
2013 Deere 4320 cab, 180 loader, 485 backhoe, 2021 Deere 1023e, Vermeer trencher, 2022 Deere 26g
How hard would it be to add a rear remote to a 2008 3320. What would be the easiest, get a kit from JD or buy a aftermarket. Where would i get a aftermarket kit, which would be cheaper.
   / Add a rear remote on a jd 3320 #2
If you only need one, then the JD option is best...You tractor already has the valve-you just have no way to control it until you buy the 3rd SCV kit that includes the control handle and linkages, the hardlines and QD's to the rear of the tractor and all of the needed hardware for about $250. All good deal IMHO.
Add to all that, there is no aftermarket "kit", you'd have to source all the pieces yourself.
do you know how easy it is to install. Does it cost a lot more if i wanted to add a second. Where does the handle come out.
   / Add a rear remote on a jd 3320 #4
Easy to install. JD does not offer a second...that gets into custom stuff and will get pricey. Next to the rockshaft lever or in the right fender-can't remember which.
i see you added more rear remote on your jd kennyd how hard was that. What did it end up costing you, how long did it take. Looks great
   / Add a rear remote on a jd 3320 #6
Yes, I have as well as many others. The cost vary a little but you can spend well over $500 without even trying hard. You also need a good understanding of hydraulics, especially all the different fitting types. I did not keep track of the time-but you can bet it will take twice as long as you think on the first project.
Here is a good thread to read: http://www.tractorbynet.com/forums/...2-hydraulic-valve-toolbox-bracket-3720-a.html
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50774)
IF YOU BID ON AN...
Agco 4210 3pt 2 Star Tedder (A50774)
Agco 4210 3pt 2...
12in Excavator Bucket (A50322)
12in Excavator...
New Edco Hand 12" Post Hole Digger (A50774)
New Edco Hand 12"...
AGCO Sunflower 20' PT Disc Harrow (A50120)
AGCO Sunflower 20'...
1999 Ford F-550 12FT. Flatbed Truck (A51692)
1999 Ford F-550...
