Oil & Fuel Add 20 year old oil to motor?
   / Add 20 year old oil to motor? #1
CobyRupert
Super Member
Washington County, NY
JD 5075E
Made the trip to mom’s house to mow her lawn with her little Honda Harmony riding mower. Forgot to bring a quart of motor oil to top off the dipstick.
The oil level was “just” below the mark on the stick. That motor only takes ~1.5qt of oil, so there’s not much to loose (if a leak suddenly got worse), and I’m occasionally mowing on some hills.
There was a case of unopened Castro 10w-30 oil in her garage. My late dad bought it 20+ years ago. I shook a bottle up, opened it, and it looked like…oil.
To use or not? I added about about 1/2 to 3/4 cup.
Was it better than nothing? Or worse than (adding) nothing?
   / Add 20 year old oil to motor? #2
I don't think there would be any issues at all. I'm not a specialist chemical engineer, but if it was sealed.... it's good.
   / Add 20 year old oil to motor? #3
I never worried about old stuff until I got old. Then I realized I was too old to worry about it.
   / Add 20 year old oil to motor? #4
Agree with the above posts....use it.
   / Add 20 year old oil to motor? #5
The only problem would be if a person uses old oil in a modern auto. Some of the heavy metals may raise havoc with the emissions.
   / Add 20 year old oil to motor? #6
Yes. Use it w/o worry.
   / Add 20 year old oil to motor? #7
For further reassurance: On the Castrol bottle will be a printed, "API donut". The center contains the viscosity, and the top part of the donut shows the API service rating "API Service S_" where the blank is likely to be an "H" (the latest and highest rating from 1993 to 1996), a "J" ('96 to 2001), or an "L" ('01 to '04). (Current ratings are SN, SP.) The ratings are said to be backward compatible.
The Honda Harmony was a machine of the '90s. If your late father kept the owner's manual, it would likely specify the rating SH or SJ. Even if you cannot find the manual, do not lose sleep over using 20 YO oil in a 30 YO motor.
   / Add 20 year old oil to motor? #8
Using old oil was better than nothing. However, I take a divergent view than the others.
Oil additives begin to lose their effectiveness in five years. OK to use in a low value motor, especially mixed with a greater quantity of new oil. But do not use by itself, and I'd not use it in an expensive motor. Good that you shook the container - any additives that separated, were remixed, and fully poured from the container.
2022 Bobcat E88 Excavator (RIDE AND DRIVE) (A50774)
2022 Bobcat E88...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50774)
ALL ITEMS NOT...
2009 PETERBILT 388 TANDEM AXLE DAY CAB (A51219)
2009 PETERBILT 388...
MAGNUM PRODUCTS LIGHT TOWER (A50854)
MAGNUM PRODUCTS...
SCREENER (A50854)
SCREENER (A50854)
2014 PJ 24+6 T/A GOOSENECK (A50854)
2014 PJ 24+6 T/A...
