Acres cut per hour
   / Acres cut per hour #1
Builder
Super Member
East PA or 750 mi. east of a short man named Dar__
Kubota, AGCO, New Holland LB
Anyone ever see a chart that combines ground speed with deck width to calculate how much acreage can be cut in an hour?
Got a finish mowing contract-about 20 acres. I usually do larger rough areas with bush hog. Would like to calculate time it will take to cut. Have to buy a flail or finish mower for the job. Would like to see what width & speed would be needed to finish it in 8 hours.
   / Acres cut per hour #2
Width of cut (as opposed to width of mower)in inches X mph divided by 100 = acres per hour (at maximum efficiency)
Deduct for time spent turning, mowing around obstructions, ect...
"Width of cut" has to reflect overlap to be anything like accurate...
This is a quick, easy way to get a close estimate.
   / Acres cut per hour #3
I remember seeing a chart like that on a website...either Scag or Exmark, or perhaps both.
Will
   / Acres cut per hour #4
Farmwithjunk,
That works out to be very accurate, certainly close enough to make me remember it. Thanks for the heads up.:thumbsup:
Thanks FWJ. Anyone think 4MPH is a reasonable speed mowing 12-18" tall pasture grass with a 8' finish mower behind my M-7040?
I usually only do bush hogging. When I bush hog, I go ~3MPH with an 8' bush hog through 5' tall weeds, but it leaves some sticking up here & there.
According to my calculations. I should be able to cut 3.8 acres/hour at 4MPH w/ 8' finish mower. I would reduce that to 3 acres per hour to account for turns. So I should be able to mow 20 acres of light pasture in under 8 hours with a 8' finish mower if I run at 4MPH.
Sound plauseable?
I pretty much got the mowing contract, now I gotta find a big finish mower. Flail or finish is the next step.
   / Acres cut per hour #7
Here's another formula that I use:
(Width of cut in feet x MPH x % efficiency)/8.25
The % efficiency in this equation reflects overlap, time for turns, etc. 100% efficiency would be like mowing full width no turning, stopping, etc.
For example:
(8' x 4mph x .75)/8.25 = 2.91 ac/hr
   / Acres cut per hour #8
Sound plauseable?
Reminds me of docking a boat, "Never approach the dock faster than you are willing to hit it."
I might consider going a little slower if the ground is hard to see the first cut. I am sure you can easily choose the right speed within a short time in the seat, just make sure you STAY in the seat.:)
Steve,
Ground is easily seen, so all is well there. I just bush hogged on Tuesday. Did about 40 acres and I'm pretty sure I was running about 2.9MPH. I'm pretty sure I could mow in 4th gear low range.
Seat belt will be buckled! :thumbsup:
   / Acres cut per hour #10
For example:
That's the EXACT formula.:) Gotta love the English measurement system. :confused2: An acre is 1 rod (16.5 feet) by 1/2 mile or 1/2 rod (8.25 feet) by 1 mile or 43,560 sq. ft. And of course there are four rods in a chain (66') which are the width of prairie road allowances (except they are 1.5 chains in some places).
The money system used to be as much fun. I visited the UK in 1965/66 when the common coins were 1/4 pence (farthing), 1/2 pence, 1 pence, 6 pence, 1 shilling, 1/2 crown (2 shillings, 6 pence), 1 crown (five shillings), and the pound.
There were 12 pence per shilling and 20 shillings per pound.
It was a challenge figuring the value of a pocket full of change. And to make it worse, the 1 pence coin was about the largest, a copper coin about the size of a 50 cent piece or silver dollar!
To confuse things further shops sometimes priced goods in guineas, which I believe was an unofficial value of 21 shillings (i.e. 1 more shilling than a pound).:confused2:
They converted to a decimal system in 1971.
More info coming soon! (A44572)
More info coming...
2019 Ram 2500 4x4 Crew Cab Pickup Truck (A42744)
2019 Ram 2500 4x4...
Fleco 24" 5T Excavator Bucket and Main Pin Thumb (A42203)
Fleco 24" 5T...
2015 KENWORTH T680 (A45046)
2015 KENWORTH T680...
102" General Purpose Loader Bucket Fits Balderson Coupler (A42021)
102" General...
2006 Nissan Frontier Ext. Cab Pickup Truck (A42744)
2006 Nissan...
