AC vs DC Welder question
   / AC vs DC Welder question #1
EdK
Central NH
Kubota M6800, Case 580E Super
I am looking to buy a generator and have followed the story line on how an engine-driven welder makes a lot of sense - particularly from the perspective of being a fellow TBNer who'd like to learn welding to support my habit. However the timing is such that I'm presented with the opportunity to latch on to a particular Miller Legend 301 where the price is right and the 1800 RPM operation is appealing for lower noise power generation and for hopefully longer equipment life.
I've noticed the bulk of the of posts from experienced TBNers/welders is to get DC stick capability. What is one giving up by not having AC?
Thanks, Ed
   / AC vs DC Welder question #2
The reason for most people preferring DC is because of the smoother and more stable arc. I have a machine that has both AC and DC capabilities. The only time I've ever used the AC is for TIG welding aluminum. I believe I can still TIG aluminum using DC, but I lose the square wave function that's desireable for welding aluminum.
If you have opportunity to pick up a 301 at a good price, go for it.
   / AC vs DC Welder question #3
ED:
when you don't have AC then you may not have a generator/welder, you only have a welder. some people like to weld cast with AC, it works for dc revers polarity normally for cast. and alum is nice for ac.
the welder/generators will have 120 volt recpticals that are 1800 rpm, and some have the idel lock function which has less load output of 120 vac, and 240 vac! the miller welder/gen sets are pretty nice we have 2 of them.
Mark M /forums/images/graemlins/ooo.gif
   / AC vs DC Welder question #4
If you need a generator and have the need for a dc welder which is by far the best for stick welding, my only question is what are you waiting for if you have found one at a reasonable price.
   / AC vs DC Welder question #5
I have an old Ac tombstone and I would gladly trade places with you. I'm sure on the ocassions that you would need AC you could borrow one.
Patrick
Mark I'm not sure I understand your comment. Sure there are 240 & 120 volt generator outlets for AC power delivery but there is no provision for AC welding with this machine so hence my original question.
I have read many TBN posts stating that DC is preferable for most all stick applications but I just wanted to be confident I was not making a decision I would later regret as I do not now have much at all in the way of welding skills and experience - just justification of a generator purchase.
Lastly the machine looks to be a good deal but even at that they don't give them away so I didn't want to be ramping up the stick learning curve only to find the machine having limited application.
Thanks, Ed
   / AC vs DC Welder question #7
Hi Ed,
Im thinking you'll not miss AC at all. If you look at the Miller site youll see the Legend cant be fitted up for AC TIG. So that rules out efficent Al welding. As someone else mentioned you can weld Al w/ DC but its not efficent and youll go thru electrodes pretty quickly. I also doubt youll be able to to weld very thick pieces. I suspect also you dont get many controls w/ this welder so smoothing out AC electronically isnt going to be an option. It can be fitted to MIG weld also. That might be handy in a pinch.
I see youre in NH. Unless this deal on the Legend is going to go away soon you might consider taking a welding class at the tech school. I did that prior to buying a welder. It was $$$ very well spent. If you want to know more drop me a PM. jimg
Thanks for the input. I'm already familar with the welding curricula at the local technical colleges - even know a graduate. I plan on taking a course or two down the road. Its' the time thing!
If I was ever going to get at all serious about TIG I would look into a Miller Syncrowave 180 or perhaps a Thermal ARC 185 inverter. At the moment I'm just trying to make reasonably sure not to shoot myself in the foot with regards to my options with stick. I do have a need for a generator as well as have a lead on the Legend so you can probably see where I'm coming from. I value the advise to get some instruction as is often mentioned in posts toward aspiring welders but if I pass on the Legend I might have to buy a generator anyways and then I'll be sure not to have an adequate welder!
Thanks again -- Ed
   / AC vs DC Welder question #9
Hi Ed,
I think youll be happy w/ the Legend as a stick rig and perhaps MIG. As for TIG I think the inverters rule the roost. I have one and its amazing what these can do in such a portable pkg. It would be a good mate for the Legend. BTW is it going to be stationary or mobil (on a wagon)?
The great thing about the welding class is that you get loads of hands on w/ many different types of machines. It helps you see the strong/weak points of each type and what would work best for your situation. I wound up w/ an inverter b/c its portable and multiprocess (Maxstar 200). At the time Miller hadnt announced the Dynasty. Otherwise I would have gotten one of those.
If you do get the welder you might also want to consider an oxy/gas rig. I use mine at least as much as the welder. Its lots easier then sawing and it can also be used to heat, braze and weld.jimg
   / AC vs DC Welder question #10
Ed, just recently I went through this. The Legend looks ideal and gives up little to the 301G.
I too like the reduced RPM generator. It obviously does not have quite the wattage ability but I would easily sacrifice that for an engine running at 1800 RPM. The Legend uses only the Kohler as the Onan does not have the electronics to utilize the various the RPM's needed for the generator/reduced weld output and full weld output. After going through all the work of learning about what Miller and Lincoln had to offer, I am delaying my purchase. The AC is for the most part not needed. If I did TIG, I would rahter have a invertor TIG unit with much more control over the current/voltage characteristics. I had originally looking at the Miller Trailblazer but after lots of investigating and talking to folks, not to mention checking the units out myself, the comparable Lincoln was a much nicer unit. I am instead going to be getting a dedicated Mig machine for now. For engine driven welding, the Legend and it's 1800 RPM is very nice. Rat...
2023 Yamaha YXZ 100R SS (A51573)
2023 Yamaha YXZ...
2012 KENWORTH T370 PROPANE TRANSPORTATION TRUCK (A52472)
2012 KENWORTH T370...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A52748)
LIKE NEW 2023...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
1989 Freightliner Cabover FLA086 (A52748)
1989 Freightliner...
2023 Dynapac cc900 Double Smooth Drum Roller (A51573)
2023 Dynapac cc900...
