AC for smaller tractor
   / AC for smaller tractor #1
yubacitykioti
Is there anything out that will give a smaller tractor the ability to have a cab with AC? Any and all info you can give on this subject would be greatly appreciated. Thank you everyone for your time. :)
   / AC for smaller tractor #2
I can tell you about my cab for the small tractors.
The http://www.cabdepot.com cabs are great. I have one on my CK20, and the heater is more than enough for any New England winter. I would bet that you could get a small A/C unit for it. That would be real nice.
Pics can be seen here: http://dmace10.tripod.com/kioti/index.album?i=5
Cab Depot has two A/C unit's available for the small tractor cabs. But they look to be about $2500 which is more than the cab itslef cost. https://www.cabdepot.com/new/view_feature.php?feature_part_number=1701-0984S
   / AC for smaller tractor #3
Is there a dealer in your area that you take your tractor for service that you can recommend
Yes, you can take it to Newton Tractor in Chico or Yuba City. The number to the one in Chico is 530-343-5032. The number to the one in Yuba City is 530-671-2061. They are the best and the most knowledgable.
The Sims Cab Depot - Manufacturers of tractor cabs, machinery cabs, enclosures, canopies and cab accessories. cabs are great. I have one on my CK20, and the heater is more than enough for any New England winter. I would bet that you could get a small A/C unit for it. That would be real nice.
Pics can be seen here: Kioti CK20
Thanks for the info.
   / AC for smaller tractor #6
There are very few tractors that can take an aftermarket A/C unit because there is no room under the hood for a compressor and heat exchanger. HP is also an issue on smaller machines as the extra hardware sucks up at 3HP.
   / AC for smaller tractor #7
Unfortunately it does draw anywhere from 4 to 8 hp to run an A/C unit with sufficient power to cool a cab that is mostly glass. If you have a hydro unit, many people say that takes away a certain percentage of power as well. So, if you were to add a cab with A/C to a 20 hp tractor, you'd end up with about a 10 hp tractor. Now try to move around and do any sort of real work at all with a 10 hp tractor that weighs 2500 to 3000 pounds or more, and you'd have one useless tractor. That is basically the thought process of why the manufacturers are not going to offer A/C in a 20 hp tractor. If it were a gear drive tractor, and weighed about 1500 pounds max, you may be able to use a 48" mower with it if the grass wasn't too high.
2008 Ford F-250 4x4 Service Truck with Liftgate (A50323)
2008 Ford F-250...
2015 Kia Sedona Van (A50324)
2015 Kia Sedona...
2011 Ford F450 Bucket Truck (A47384)
2011 Ford F450...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2014 Nissan Frontier Ext.Cab Pickup Truck (A50323)
2014 Nissan...
2007 Peterbilt 335 Mickey AO-A Battery Truck (A50323)
2007 Peterbilt 335...
