AC D15 loses power and dies for no reason, help!
   / AC D15 loses power and dies for no reason, help! #1
laitec
AC180, AC D15,IH 400
I was planting oats yesterday and the engine began to race but it lost power and quit. I waited a minute or two and it returned to idle and went but soon the same thing happened. I thought maybe it was overheating so I added anitfreeze, topped off the oil, but the same thing happened .. It happened more often on the up slope but also on down hill. I recently had the engine overhauled. The head milled. In fact the problems seemed to start soon after. I am completely at a loss.:confused:
   / AC D15 loses power and dies for no reason, help! #2
I'd check the fuel bulb and make sure there was no water or trash in the gas tank.
   / AC D15 loses power and dies for no reason, help! #3
If it's a grass tractor, there something wrong with the fuel delivery. trash in the tank outlet strainer, clogged fuel filter or sediment bowl. etc
   / AC D15 loses power and dies for no reason, help! #4
That's it sediment bowl. That's what I meant when I said fuel bulb.
   / AC D15 loses power and dies for no reason, help! #5
I meant Gas Tractor.....
   / AC D15 loses power and dies for no reason, help! #6
If it is a diesel, I would suspect the injector pump is about to go out. I sure hope it doesn't do like a AC D17 we had once when the pump went bad it started racing WOT 2-3 times normal RPM. Luckly my Dad was driving it and was able to shut off the fuel valve at the tank. He said he believed if it had not been overhauled with new rod bearings and rings, it would have thrown a rod and ruined the engine.
2018 Bobcat T595 (A47384)
2018 Bobcat T595...
377789 (A51573)
377789 (A51573)
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A53472)
John Deere 6105E...
BUSH HOG 7007 LOT NUMBER 116 (A53084)
BUSH HOG 7007 LOT...
2017 Ford F-550 4x4 Enclosed Utility/Air Compressor Truck, VIN # 1FDUF5HT6HED32921 (A51572)
2017 Ford F-550...
2018 CASE IH 110N LOT NUMBER 223 (A53084)
2018 CASE IH 110N...
