AC 5020 (Hinomoto E230) Charging issue
   / AC 5020 (Hinomoto E230) Charging issue #1
rrgrassi
Royse City, TX
Hinomoto E230
I am the new owner, and am going through repairing the hack jobs by the PO :mad:. Newest one is the charging system. It is a Hitachi alternator with three wires that connect. I am not getting any charging voltage.
One is the BAT connection which traces fine to the starter and the battery connection.
The other is a two prong connector that looks to plug into the internal regulator. It looks like a capital "T". One wire has been cut and removed, that one would be the top of the "T". I believe that one goes to the idiot light. I do not know if this model needs a functioning idiot light to make the charging system operate. I do have a manual, and that circuit shows a diode, light and resistor. It does not give the size of the resistor.
Can anyone help me with this issue, and how to rewire it properly? I do know that it is possible that a replacement alternator may be needed.
Thanks!
Here is an update... I have the alternator off the tractor. The electrical connections are Bat, S, L, E. The S is not used, and there is no tab on the diode set for S. So only Bat, L and E are used.
I'm taking it to Auto Zone for testing.
Had to replace the alt. Found a supplier that had a Mitsubishi that was an exact fit. Charging at 14.2 now.
Gray's Auto Electric & Starter had it. They can also rebuild any alt or starter. They are located in Wylie, TX.
**SALE ORDER ANNOUNCEMENT** (A51242)
**SALE ORDER...
1993 Mono Dump Trailer (A50514)
1993 Mono Dump...
2018 John Deere 470G Hydraulic Excavator (A50322)
2018 John Deere...
Caterpillar 730 Articulated Dump Truck (A49346)
Caterpillar 730...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
