AC 5020 4WD front end bearing part numbers needed....
   / AC 5020 4WD front end bearing part numbers needed.... #1
montejw
NW WA State
1980 AC 5020
Do you have a parts catalog? Can you give me the part numbers for the bearings in the front end with 105 balls, the seals for those bearings, and the seals/bearings on top of the axle housing?
I'm looking for those parts at salvage sites and they need the part numbers.
Thanks,
Monte
I found some.
Monte
   / AC 5020 4WD front end bearing part numbers needed.... #3
Just curious, wonder why bearings failed (were front tires loaded)?
I'm not totally sure. I've read of other 5020's doing this. On mine one bearing race fell apart on one side. On the other side the races were loose in the axle housing. Part of what might have been a problem on mine is one of the thrust bearings on top of the axle housing was mostly a piece of rust and allowed some side to side movement.
They didn't just fail, it's a long slow process it looks like to me.
Monte
71062 (A49346)
71062 (A49346)
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
AC CHARGING MACHINE (A50854)
AC CHARGING...
THIS WILL BE A LIVE VIRTUAL ONLINE AUCTION! (A50657)
THIS WILL BE A...
2014 Therm Dynamics TD400 Towable Flameless Heater Trailer (A49461)
2014 Therm...
