About Clutch and PTO - CK20 HST
   / About Clutch and PTO - CK20 HST #1
DViau
Frelighsburg, Quebec
Kioti CK-20HST
I am using my new CK20-HST with a rear mower. My question is: is there a way to shift from Low to High without using the clutch because if I use it, the PTO Stop and so I have to reduce speed in a way to have the PTO running again (because I don't want it to have the PTO back at full speed).
Need your advice.
Denis
   / About Clutch and PTO - CK20 HST #2
When my dealer delivered the tractor, he just pushed the brake and shifted from low to high and pulled it off the trailer. I use the clutch just because but it will not harm it by not using the clutch. I have done it a couple of times without thinking.
Just make sure you use the brake because any slight movement will make it very hard to shift.
   / About Clutch and PTO - CK20 HST #3
there are only 2 times to mash the clutch on a Kioti CK HST tractor...
one time is when you start the engine.
the only other time use the clutch on a Kioti CK HST tractor is when you engage the pto...
other than that, please keep your foot off the pedal.
   / About Clutch and PTO - CK20 HST #4
I clutch when shifting ranges. Thought I was supposed to.
   / About Clutch and PTO - CK20 HST #5
the manual says to use the clutch. I beleive this to be a safty precaution. As long as the machin is not moving and the HST motor is not turning there shouldnt be an issue. I think it is mearly a final drive selection and not in the hst motor itslef. The only reason i can think of that they tell you to do this is because it does stop the pump that drives the HST so that you are sure it isnt turning. I have done it before with a rotory cutter running with no issues. if the machine is moving slightly you will get a slight grinding of gears. That is why i fell like it is in the final drive and not the HST.
2 Axle Trailer (TITLE) (A50774)
2 Axle Trailer...
Unused 2025 CFG H15 Mini Excavator (A50322)
Unused 2025 CFG...
2014 Landoll VT-Plus (A52349)
2014 Landoll...
Bobcat 3560 Skidloader Breaker (A50774)
Bobcat 3560...
CFG Industrial Q.A Hydraulic Breaker (A50121)
CFG Industrial Q.A...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50323)
2016 Big Tex 14LX...
