???? about changing hyd/tranny fluid on a 790
   / ???? about changing hyd/tranny fluid on a 790 #1
kebo
Elite Member
Lexington, SC
2001 John Deere 790 4x4, bar tires
I'm about to change the hyd/tranny fluid on my 790 for the first time. I already have the filter, but still need to get the cheap & inexpensive JD Hy-Gard fluid at my local JD dealer this week. My manual says I need 4 gal's, that's fair enough. But, will I need some extra with the loader on it? The manual mentions nothing about the loader. Or, is that irrelevant cause the loader won't lose much (if any) when I do drain the tranny? Also, any tips on removing the internal mesh wire screen, or the vent tube on top of the axle housing?
Thanks!
   / ???? about changing hyd/tranny fluid on a 790 #2
You will only be draining oil from the sump, not the loader. But. OTOH, extra fluid is always good to have around.
   / ???? about changing hyd/tranny fluid on a 790 #3
Just changed fluid 10 tractor hours ago.
5gal. bucket will not fit under 790 with R4s while setting on ground.
Make sure JD fluid is Low Viscosity HY-Gard.
Filter has to be partially filled before it is installed and I bought the 5gal. bucket so can't tell if exact 4gal. but looks like it. Loader did not matter. Filled 3 3/4 gal. then topped off.
Used 2 funnels. 1 to fill 1gal. jug and 1 large hole funnel that set tight in fill hole. (got at walmart.) (I had help filling jug.)
Had to disconnect break linkage rod from pedal to remove screen. Messed up cotter pin removing linkage so had to replace with new one.
dirt ditch, you read my mind! I was planning to use a 5gal bucket to catch the old fluid in too, but will have to come up with something else. That's another good tip about the brake linkage being in the way of removing the screen too. I'll look that over before I get started to see if it's gonna be a problem for me as well. Thanks for the info!
   / ???? about changing hyd/tranny fluid on a 790 #5
The screen is too long to be pulled out of the housing with out disconnecting the brake linkage and swinging it back out of the way.
You may want a pan and brush with gas or solvent to clean the screen. It is a very fine screen.
Good luck
   / ???? about changing hyd/tranny fluid on a 790 #6
I'm not sure if it helped or not, but I raised the loader all the way up, drained the fluid, then lowered it. Figuring it would push fluid out of the cylinders on the pressure side and only suck air on the return side.
2015 DODGE RAM...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A53473)
2022 Quick Attach...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2016 JOHN DEERE 3032E LOT NUMBER 94 (A53084)
2016 JOHN DEERE...
2013 CATERPILLAR 320EL EXCAVATOR (A51246)
2013 CATERPILLAR...
2013 International TerraStar Enclosed Service Truck with Liftgate (A53422)
2013 International...
