?? About buying flail mower at auction
/ ?? About buying flail mower at auction #1
AlbertC
Perry, GA
New holland 3930
My local county is going to have an excess/obsolete equipment auction and I noticed they have several Alamo flail mowers.
If the mowers look complete and are not just a rusty pile of junk would they be worth buying and repairing? assuming that some major parts need replacing could I purchase the parts and stil make this a worthwhile purchase or could one or two major parts needing replacement make this not such a good deal. I am assuming at this point that I can purchase the mower for a pretty good price.
/ ?? About buying flail mower at auction #2
Make sure the one(s) you buy have the following:
1- modular bearing assemblies (pillow block or any other type of bolt-on carrier)
2- no cracks in drive box
3- inspect the rotor and be sure that no balancing weights have come off... getting the rotor balanced is about the most expensive repair to be made on a flail, short of replacing the rotor
4- make sure the rotor isn't bent or cracked, and that all knife flanges are in serviceable condition
Anything else is fairly simple welding or cheap part replacement. Modular bearings ensure that you will be able to find bearings, even if they aren't available through OEM... and the fact that they're field serviceable is always a plus.
As a further note, I wouldn't buy a flail mower that doesn't have a rear roller. The reason is, most flail mowers without the rear roller are heavier than those with them, and the assembly sees A LOT more stress... ESPECIALLY with municipal/state use, as their operators don't own the equipment, nor do they practice any care in its use.
For just a couple hundred more, you can usually find brand new flail mowers on GovDeals.com that are still in the crate (minimal shipping cost) and avoid 99% of ownership/operating cost of a used one.
Equipment is an odd purchase at these auctions. Power units (tractors, etc.) are usually sold on a time of service basis. Implements/attachments however, are usually only sold when they have little to no serviceable life left in them... so buy with caution. If you plan on putting more than 40hrs a year on it, I'd suggest buying an overstocked new unit (check Proxibid or GovDeals)... as they can usually be had for only slightly more money.
/ ?? About buying flail mower at auction #3
Multimow is generally correct. Make sure the rotor is in good shape, that's the expensive part. Gearbox 2nd, but you can reasonably replace that. Don't bother if there is no rear roller, it can be replaced but won't be useful without it.
I'd love a good cused ounty Alamo flail to my old beat to **** 7' Ford 917 flail. An Alamo or any count roadside mower is going to be a much heavier duty rig than my lighter duty 917. Knives & bearings can be replaced without to much pain or expense.
Thanks. Thats good information to consider.
/ ?? About buying flail mower at auction #5
Buy from Gov Deals and currently have 2001 Dodge that I got stuck with. Before that got a 1997 Ford F-250 from Tipp City Ohio with blown head gasket. Bought a flail mower off of Fairborn Ohio{ Alamow} for 250 dollars went to pick it up and asked about extra blades. Guy that loaded the mower found them. I was looking for him to throw them on the trailer - he had to ask the boss. Told me they had to be sold. Offered 100.00. Nope had to go up for auction. The new box of knives for the mower I bought brought 300.00. I did not bid or buy. Did not need any blades for the old mower to mow well. Set on it today watching leaves fall. You are taking a chance at auction good luck. Do not buy lottery tickets or play poker. Auctions are addictive enuff.
/ ?? About buying flail mower at auction #6
The Mott brand which was bought by Alamo are well built if you can pick one up that operates and you consider it affordable by all means buy it parts are available thru flail master in Tenn.hard to describe but if you mowed with one you’ll be hooked
2011 Chevrolet Express 2500 Cargo Van (A61573)
2011 Chevrolet...
2017 Ford Escape AWD SUV (A61569)
2017 Ford Escape...
MINI FLAT BOTTOM GRAPPLE (A61572)
MINI FLAT BOTTOM...
1947 Chevrolet Panel (A62613)
1947 Chevrolet...
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
Tree Boom Skid Steer Attachment (A61572)
Tree Boom Skid...
