tomrscott
I found a real good online catalog with a lot of application data about all types of hydraulic fittings:
http://hydraulics.eaton.com/products/pdfs/W-HYOV-MC001-E_application_data.pdf
It's the Weatherhead company, recently acquired by Eaton. They seem to be a bit supplier of this stuff.
Anyway, I was looking for a reference to banjo fittings. But with all the stuff this place has, they didn't have anything that helped. The SCV on my JD790 uses those at all the ports. I am not finding these connectors in any of the usual places.
I found a British company that had British threaded banjos that then convert to a tubing coupling.
http://www.indanc.com/steel-compression-fittings-06.htm
I noticed that they say the male thread that compresses the banjo part, is available as a BSPP or metric thread.
But that begs the question, what is the thread on the JD banjo going to be? Is it going to be metric? Or does JD/Yanmar use American standards for those things?
Is it possible that some other male threaded fitting, not necessarily a banjo can be screwed into the port that they've connected a banjo to? The tubing that is connected with the JD banjo appears to be 3/8" with 0.485" OD. The hex head on top of the banjo is approximately 1.07", didn't have a socket set handy to try and see what fit. The banjo ring that is clamped by the "bolt" is about 0.7" thick. I don't really want to take these things apart until I am ready to re-do it. I suspect they could be real tight, and the quarters are cramped. I need to tap into the hydraulics PB at the FEL SCV and then return to the rockshaft P port.
I am just wondering if the port this banjo is screwed into is actually a 1/2" NPTF or something that I can put a standard 90 ell with a compression coupling on the other side?
Maybe I don't need to find a banjo?
Anybody know what these threads are, or a source for the correct banjo fittings? I'd like to run tubing for the power lines to the TNT, but may settle for hoses, but I have to figure out how to connect to those.
Thanks!
Thanks!
