?? About Antifreze
   / ?? About Antifreze #1
AlbertC
Perry, GA
New holland 3930
I have a 1999 new holland 3930. I am going to change the antifreeze and according to the manual you are supposed to ad an "inhibitor" with the antifreeze water solution. I asked my new holland dealer about this and he said they didn't have any and to not worry about it, just to put a good quality antifreeze in the tractor.
Any opinions about this? I feel they wouldn't have specifically mentioned the need to add this inhibitor in the manual if it was not needed, but on the other hand,maybe antifreeze has improved since my tractor was made and the inhibitor is no longer needed.
What do you think.
   / ?? About Antifreze #2
I'm about sure all antifreeze's have corrosion inhibitors in them. Supposedly those are what actually wears out in old anti freeze.
   / ?? About Antifreze #3
Albert, the dealer should have had it and it is a concern on ALL diesels. He could have said 'any good diesel antifreeze' would have been more correct. FW15 from New Holland *which the dealer should have) added to good standard antifreezes is one solution. Diesel antifreeze can be purchased at an auto or truck parts store.
   / ?? About Antifreze #4
Most of today's premium extended coolants such as Caterpillar's ELC do not require inhibitors and the change intervals have increased to thousands of hours and two to six years depending upon the coolant and usage. On a side note the term "coolant" is fast overtaking the term anti-freeze as the engine manufacturer's continue to increase engine operating temperatures to reduce emissions. The days of using water as an engine coolant are long gone due to the high operating temperature limits of today's engines. Bottom line- In today's world I agree with the dealer... if you use a brand name extended life diesel engine coolant you don't need to add inhibitors on the initial fill. jc
   / ?? About Antifreze #5
If your tractor has a wet sleeve anti cavitation additives are used in the coolant.
In the past few years the coolants have changed so I sure you use the proper one.
   / ?? About Antifreze #6
That is a new one to me. I never heard of "Diesel antifreeze," and I had diesels a long long time. I'll have to check that out. I always thought there was the green antifreeze and the newer orange for aluminum blocks engines. I better quit there before I show my igoranse.
   / ?? About Antifreze #7
Like Egon said, cavitation corrosion can be be an issue in certain diesel engines.
http://www.advantageengineparts.com/pdfs/CavitationErosion.pdf
Older formulations of coolant relied on SCA (or DCA) additives to deal with this issue. As stated well already, the newer good quality formulations of extended life diesel coolants deal with cavitation corrosion issues, w/o needing SCA added.
Ex. Chevron Delo ELC
https://cglapps.chevron.com/msdspds/PDSDetailPage.aspx?docDataId=76884&docFormat=PDF
Less commonly an issue, but I've read that cavitation corrosion can also occur in certain gasoline engines.
The belt-and-suspenders approach (which I agree with) is "If you have a diesel engine, use a coolant that offers cavitation corrosion protection". It's way cheaper to have it, and not need it, than the other way around.....
Lots of good diesel ELCs out there now. One of the reasons I went with Delo is that it will tolerate the presence of other coolants (25% max) better than some earlier ELC formulations.
Rgds, D.
   / ?? About Antifreze #8
Albert
Some of the information above talks about wet sleeve cylinder bore liner "cavitation" erosion. If your tractor engine has wet sleeve bore liners you normally either need to add a supplement to the coolant or buy a coolant that has the Supplemental Coolant Additives (SCAs) included. The other option would be to use a coolant that controls the cavitation erosion without the Supplemental Coolant Additives (SCAs). Either way I would suggest to use a "long life" coolant. The long life coolants still use ethylene glycol to increase the boiling point and decrease the cooling point but have a different corrosion package. Many use Organic Acid Technology (OAT). Look up Peak Final Charge on their website. Other are available as well.
I just changed my tractor engine coolant which does not have wet sleeve bore liners. I used Peak Brand Final Charge Nitrate Free Extended Life Engine Coolant mixed 50/50 with distilled water. It controls the erosion/corrosion without adding SCAs. They also have a version that has the SCAs added. Final Charge meets the specification of many HD Diesel Truck and Engine Manufacturer's. For off road engines from memory it is rated for up to 8 years and 20,000 hours. I will never get close to 20,000 hours but the 8 year change interval is desirable. Standard life coolants are typically rated for two years change life. When you change your coolant be sure to flush out the old coolant with clean water so none of the old coolant is remaining. Might be good to use a cleaning flush to clean the system. I see Preston brand at most auto parts stores.
Take care and remember that engine coolants are toxic. Do not leave it open or in a puddle on the ground where children / people, pets, and animals can get to.
Wayne
   / ?? About Antifreze #9
Albert, the dealer should have had the coolant or additive in stock, in my opinion, but at least differentiated between plain old green coolant, like Prestone and those designed for diesels.
Ford tractors' older blocks were heavy cast and didn't suffer from liner pitting. Later blocks were lightened up and reinforced. You can see this in your 3930 in the 'X' pattern on the block sides. They are not wet sleeved blocks either, but both wet sleeve and parent bore blocks are susceptible to liner pitting.
As was stated, it is cheap insurance to use a coolant designed for diesels, and as Wayne stated, for a little more money, extended life coolant is the way to go.
In the farming industry where there is hired labor, ELC's are great until someone starts adding water or cheap coolant to them. Then the purpose is defeated.
   / ?? About Antifreze #10
Long time diesel user and never heard of special anti freeze. Learn a lot of things I should have known on this site. Will be changing anti freeze in truck and tractor soon. Thanks
2015 FORD F-150 (A45333)
2015 FORD F-150...
Graco LineLazer IV Airless Line Striper (A44571)
Graco LineLazer IV...
3Pt Ditcher (A44502)
2012 WESTERN STAR 4900 (A45046)
2012 WESTERN STAR...
2016 VOLVO VNL TANDEM AXLE SLEEPER (A43004)
2016 VOLVO VNL...
2016 Ford F-350 4x4 Pickup Truck (Diesel), VIN # 1FT8W3BT4GEC38506 (A44391)
2016 Ford F-350...
