A64 Ford Wheel Loader
   / A64 Ford Wheel Loader #1
kf4uda
Veteran Member
Middle TN
NH TD5030, 861 Ford Powermaster, CaseIH Farmall 35A, 555A Ford Backhoe, S150x SnapperPro ZTR, Polaris Ranger XP800
I am having a problem with the brakes on an A64 wheel loader. I started the loader and discovered that the brakes were not working. The pedal have little to no resistance when pressing them. I am not familiar with the brake system on this machine at all. The machine belonged to my Dad who passed away almost 2 years back.
Do any of you guys have an idea of where to start looking for the problem? I know he had a service manual around somewhere for this machine, I just have not found it yet.
   / A64 Ford Wheel Loader #2
first things first check for fluids. there is an o-ring in the differential that sometimes goes and just pours fluids into there...been there done that....
Thanks for your reply. You were exactly right about the fluid. I didn't realize that this machine had a brake pump. It looks exactly like the pump on my 555A TLB which is the power steering pump so I assumed.....I found the service manual and looked up the brake system. After rubbing the stupid sign off of my forehead, I filled the brake reservoir. Brakes work great now....imagine that! I also found a post on the net that discussed the o-ring problem and found that I can get a seal kit for it.
Again I thank you for your reply salopez.
2017 Nitro Z 19ft Bass Boat with 26ft T/A Boat Trailer (A51694)
2017 Nitro Z 19ft...
1990 Nitro Tracker 165TF Bass Boat with S/A Galvanized Trailer (A51694)
1990 Nitro Tracker...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53473)
2012 JOHN DEERE...
2016 CATERPILLAR 325FL EXCAVATOR (A52705)
2016 CATERPILLAR...
2022 DRAGON  130BBL VACUUM TRAILER (A53843)
2022 DRAGON...
2015 ISUZU NPR 16FT BOX TRUCK (A54313)
2015 ISUZU NPR...
