A300, Ideal RPM ?
   / A300, Ideal RPM ? #1
blunosr
Bronze Member
Northern BC, Canada
Kubota MX5000, Ford 5000, Massey Ferguson 1080, Bobcat A300
Hi, I'm wondering what RPM you guys run your machines at?
My machine is a 2005, A300 with 2-speed, turbo, and high-flow hydraulics.
On the road I generally run around 2300, and working around with the bucket or forks etc. I most often am at about 1700rpm.
Should I run in low range, but with higher rpm?
What about running an auger? I have a 15c and have drilled holes up to 14' deep using my high lift auger mount. I find that I want the bit to spin slowly, but I do need high engine rpm to keep up the torque. Is there a better way to run it?
Thanks,
   / A300, Ideal RPM ? #2
Most Bobcat equipment is designed to run between 2/3 and 3/4 throttle in most applications; moving dirt, using pallet forks, etc.
For road travel, I would say run full throttle so you can get your peak travel speed, especially for 2-speed travel.
As far as your augering holes, if you are consistantly digging deep you would have better success by jumping to a Bobcat Model 30C auger. It is designed for a slower turning speed and higher torque for standard hydraulic flow.
Here is a link to Bobcat's website talking about the auger attachments.
I hope this helps you.:cool:
2020 Mathieu MC210 Azura Flex Street Sweeper (A51691)
2020 Mathieu MC210...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A51246)
2021 HAMM HD+9I VO...
ECHO SRM-225 GAS WEED EATER (A51248)
ECHO SRM-225 GAS...
International Acid Tanker Truck (A52377)
International Acid...
UNUSED FUTURE 19" EXCAVATOR RAKE (A51248)
UNUSED FUTURE 19"...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
