A WELL problem
   / A WELL problem #1
PILOON
Super Star Member
North of Mtl,Que,Can (Ste Adele)
MT180D
One of my client's well simply gave up supplying water.
Well was proper artisan installation about 40 years old but simply gave up. Local dynamite work was partially suspect.
I contacted many drillers and they all wanted to drill a brand new well giving all sorts of reasons all of which would cause considerable additional costs like excavation being a serious concern considering stone walls and other landscaping features.
The winter snow accumulation also needed to be taken into consideration as well as frozen ground.
Typical quotations ran above $12K until I located this one chap.
The common excuse was that re-drilling was a big risk to damaging their expensive drill bits.
Using a reference from my pump supplier and my gut feeling I selected one chap that offered a few excellent ideas.
His quote was to be about $5-6k 'depending' on a few things like hydro fracture and naturally footage. All fair and understood.
His tactic was to use his older bit that was somewhat warn out so that it could not get jammed in the existing pipe.
He needed to thaw the ground (about 1 hr) to remove the lid, drilled down an additional 140 ft installed our new pump, wires hose etc, re sealed and tested everything to our satisfaction. His tests were that we had 100-120 GPH.
Most drillers wanted to immediately come to sign a contract, this guy actually simply gave a handshake.
When he declared that we had a successful well I asked "How much are we at?" (still another 1 1/2 hr to go)
The answer was $3200.
He skipped the hydro fracture step as our supply was adequate as well as we now had an additional 140 ft of reserve.
All I can is that is just just so nice to deal with an honest person.
The whole experience was a most pleasant one for me and my clients. In fact we all were joking and kidding along during the whole process.
We also lucked out in that the government delayed the highway spring thaw regulations thereby allowing him to bring in his heavy equipment.
Not only that but in as I get contractor discounts he did not get upset that we supplied all the materials.
   / A WELL problem #2
Nice result..Great that there are good people left out there...Thankfully, my well driller operates on a similar premise.
   / A WELL problem #3
Best thing you can do for a guy like that is advertise as much as you can for him by word of mouth. Awesome turn out.
   / A WELL problem #4
Absolutely...I do the same wherever I can too.
   / A WELL problem #5
^+1
Make sure that you recommend him whenever the subject of well water comes up in your travels.
My dad built a very successful business by leaving customers satisfied that he did everything he could to make them the winners, even if it wasn't the most profitable (immediate) solution for his business. This long view, and a stack of business cards that he handed out to satisfied customers, was what separated him from a lot of slick, high ticket competitors.
   / A WELL problem
Well, it will pay off very soon as I have been retained to be 'site manager' for a new build this summer and a well is one requirement for mortgage and city permit even though they are lakeside.
(Our lake a is only spring fed and annual testing over 20 years has provided consistent excellent drinking quality results. Water at the thermocline level is always A-1 quality and most of us use an infrared system to assure safe consumption).
The lake is at the top of the water chain and as such has no inlets.
2013 CAT 950K WHEEL LOADER (A52472)
2013 CAT 950K...
UNUSED LANDHONOR 82" FORK EXTENSIONS (A54757)
UNUSED LANDHONOR...
2010 Nissan Rogue SUV (A53424)
2010 Nissan Rogue...
CUSHMAN HAULER PRO GAS GOLF CART (A54756)
CUSHMAN HAULER PRO...
2018 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A52377)
2018 Allmand...
Case 1150G Crawler Tractor Dozer (A53421)
Case 1150G Crawler...
