A warning for those considering a Gear Drive Kubota L2501
   / A warning for those considering a Gear Drive Kubota L2501 #1
Foxtail
Willamette Valley, Oregon
Kubota L2501
I want to tell my experience with a Kubota L2501 in case it's useful to anyone considering this tractor, or a L3301. They are wonderful tractors but the buyer should be aware of the following if you're not planning to get a hydrostatic....
First some background: I cut 10 acres of rough land 1-2 times per year. I did this successfully with a John Deere 1023E tractor and 4 foot Frontier RC2048 cutter. The 1023E's ground clearance around the transmission was fairly low, however, and the ride was a bit rough. So I wanted to upgrade this summer. I wanted a Deere 3032E with 5 foot cutter but it ended up being more than I wanted to pay, especially since I am unlikely to ever put that many hours on the tractor. The new Deere 3025E seemed better for my budget, but is not out as of this writing, and in any case my John Deere dealer said it has only 17.4 PTO horsepower and thought that is too little for a 5 foot cutter.
So I talked to Kubota dealers, and they were quite supportive of putting a 5 foot cutter behind a L2501, which has better PTO horsepower than the Deere (and up to 70.2 lb-ft of torque, incidentally, compared to 51.3 for the 3025E and 64.2 for the 3032E; although torque is not probably as important as PTO HP).
I ended up with a Gear Drive Kubota L2501 with 5 foot Land Pride RCR1260 cutter. The gear drive saved maybe $1000 and offered more PTO horsepower (20.5 PTO HP vs 19.0 for the L2501HST). HOWEVER, the gear drive was a big MISTAKE for my situation:
Problem 1: Nonlive PTO. When mowing if you ever need to change a gear or reverse, you must fully depress the clutch pedal, which also shuts off the transmission-driven PTO (and rear cutter). If you are in heavy material and want to slow down or back up, your only choice is to raise the mower and keep going (but not getting the grass cut) or to put the clutch in, bringing the tractor and PTO to a complete stop. (Note that the gear drive L3301 also has nonlive transmission-driven PTO. The L3901 gear drive might have the advantage of a two stage clutch pedal, which can let the PTO keep going as you change gears. However, buyers should check this carefully).
Problem 2: There are only 8 forward gears on the L2501 and they are spaced somewhat widely for mowing. It's hard to find the specs, which are only in the Kubota owner's manual and not online. Here are the details:
Low2 is 1.1 mph (much too slow for mowing except for very heavy conditions)
Low3 is 1.6 mph (very slow for mowing -- much slower than I generally did in my 1023e with a much smaller engine -- but this is the most realistic option for most conditions)
Low4 is 2.8 mph (substantially faster than L3, and generally too fast for mowing for all but the lightest material -- but still may not get a good cut because you're going so fast)
Also: on the L2501 (unlike L3301 as I understand it) there is no shuttle shift, which means that if you want to go from forward to reverse, you have to fully depress the clutch, come to a complete stop, which shuts down the PTO as well, and slowly shift and let your clutch out again. To save the clutch, the PTO and the implement, you really should do all this at fairly low RPM. However, since this action is also how you get the tractor to start moving again, you need some power -- maybe 2000 RPM to get the whole thing to go. Your left leg will really get some strength training!
Anyway, a gear drive L2501, with its transmission-driven PTO and somewhat widely spaced gears, is a little bit like a 1950s type tractor, and is not for everyone! I am sure there is someone out there who loves it, and will promptly tell me I'm just inexperienced. If someone has had a good experience with this tractor, please share.
After nearly 5 hours of frustration, my dealer let me trade up to a L2501HST, which essentially solves the problem. I would not hesitate to recommend the L2501HST to anyone wanting to run 5 foot implements.
   / A warning for those considering a Gear Drive Kubota L2501 #2
Sounds like a good dealer.
   / A warning for those considering a Gear Drive Kubota L2501 #3
Didn't know they made any tractors now without live pto. Thanks for the info.
   / A warning for those considering a Gear Drive Kubota L2501 #4
They have a 2 stage clutch and it does not have to be pushed all the way down to change gears. If you push it half way down you can change directions or gears without stopping the PTO. It is hard to get use to after having a regular clutch for so many years
   / A warning for those considering a Gear Drive Kubota L2501 #5
This is interesting. I bought my l3301 with gear drive to use 80% of the time pulling a 5 ft bush hog, and a 5 ft finish mower. After 75 plus hours I have no complaints. I haven't even thought about this. Am I blissfully ignorant, or just blessed?
   / A warning for those considering a Gear Drive Kubota L2501 #6
("Am I blissfully ignorant, or just blessed?") <<<<<<<<I'd say with that much orange on your list, your blessed............
   / A warning for those considering a Gear Drive Kubota L2501 #7
Far as I'm concerned, gear tractors are only good for hauling wood, not for mowing/farming............
   / A warning for those considering a Gear Drive Kubota L2501 #8
Glad your dealer was able to help you out.We have one of each gear/hydro.......I much prefer the HST for what I do with mine.
   / A warning for those considering a Gear Drive Kubota L2501 #9
You buy budget, you get budget. :confused3: Just like buying cars. I'm looking at the Ford Fusion. It will most likely be the last car I buy since I'm driving a 92 Taurus LX now with only 81k miles. The difference between the basic Fusion and the Titanium or Platinum is miles apart in amenities. They'll practically do your grocery shopping for you. But I'm dead set on Sync and Navigation. The other stuff is a bonus. :)
Click on attached picture to expand it and see why I claim that the Gear Drive L2501 does NOT have a 2 stage clutch. If you expand the picture you can see the warning sticker right on the instrument panel that reads "IMPORTANT: BEFORE SHIFTING FULLY DISENGAGE THE CLUTCH AND COMPLETELY STOP THE TRACTOR". View attachment 484010 This was actually a surprise to my dealer, who at first didn't know this either (neither of us had tried out this particular tractor before it was delivered). Because of this surprise, they were quite willing to allow me to trade up for an HST with no penalty. _lutc.jpg
Ford 6.2L 4x4 Automatic Transmission | OEM Replacement | Fits F-250, F-350, Super Duty (A44789)
Ford 6.2L 4x4...
2015 John Deere X730 54in Ride-On Mower (A42744)
2015 John Deere...
2017 Ford Explorer AWD SUV (A42744)
2017 Ford Explorer...
2006 Ford F-150 XLT (A44501)
2006 Ford F-150...
2016 GENIE GS-2632 ELECTRIC SCISSOR LIFT (A45046)
2016 GENIE GS-2632...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A43004)
2019 INTERNATIONAL...
