A very simple fix for non-functional jd2305 PTO
   / A very simple fix for non-functional jd2305 PTO #1
SI2305
I am writing this post because of a VERY simple no-money fix to a potentially calamitous problem. As I stated in another post, my old jd2305 that I sold to my next-door neighbor had the PTO fail just after he bought it. I felt pretty guilty, thinking that I had sold him a lemon, but the solution was remarkably simple. In this case, the solenoid was simply stuck, having sat over winter with no use. The basic symptom was that after we pulled the dash switch for the PTO to start, the PTO would simply not engage. We checked to make sure that the rear PTO would spin freely when only the mid-PTO was selected and it would. Further, when the rear PTO was selected, the PTO would be solidly in place (could not easily turn with my hand). The tractor ran just fine in all other respects. I called the dealer and they suggested that the clutch or transmission needed to be replaced (dead wrong here), and since the PTO would either be firmly engaged or spin freely as we expected, we tried looking at the electrical side. We did check the fuse box and the fuses were fine. Ultimately, a little checking online suggested the solenoid might be the problem. At first I thought this meant replacing the solenoid, a much better option than the clutch or transmission, and after tinkering around, we found a very simple solution as I will try to detail below.
Firstly you need to find the solenoid. On the 2305 it is located above/behind the right rear tire. There is a little cut-out hole in the frame to allow access.
Next, after confirming that the solenoid had electrical power, we simply took a long screwdriver, placed it up to and touching the rear point of the solenoid and tapped firmly/gently about 3 times. The motion that worked best was when we tapped in line with the solenoid which in this case was forward, in the direction of the tractor. We had previously tried tapping on the rear in a sideways manner and this did not work, nor did simply tapping the frame near the solenoid. A direct tap on the rear in a fore-and-aft movement was enough.
Finally, we started the tractor, pulled the PTO switch and the PTO worked perfectly. We went and hooked up a PTO implement and started it and it worked perfectly fine.
I am writing this up here hoping others can use this extremely simple procedure to avoid a potentially costly and unnecessary repair.
Best of Luck,
SI2305
Former JD2305 owner
Current 2018 JD2038 owner
Jd 2018r, Loader, 6' rotary cutter
   / A very simple fix for non-functional jd2305 PTO #2
Great news. Happy you found the fix. Thanks for sharing the fix
You are more than welcome. I just hope that others having this same problem can get easy access to the simple fix. I would like to spread this information around more so more people can get easy access to it.
Si2305
   / A very simple fix for non-functional jd2305 PTO #4
Would be quite helpful if there were some pics to show "the access hole" you mentioned, as well as the part no. of the solenoid being discussed, and the schematic that shows the solenoid that was "bumped" into working order.
just sayin...
Thanks for taking the time to mention the "fix" that worked for you.
Beenthere,
I will see about getting some better documentation. However, as the 2305 is no longer mine, it is a bit harder than before to get pictures of it. My neighbor (new 2305 owner) is gone for a few days, but when he gets back, I will try to get some pictures of the tractor plus a picture of the exploded diagram showing where the solenoid is located. As far as part number, that piece of info never entered into our fix.
SI2305
   / A very simple fix for non-functional jd2305 PTO #6
thanks for the help back at it tomorrow! Does anybody know what the 4 fuses in the box do?
   / A very simple fix for non-functional jd2305 PTO #7
I don't know how common this is, but it happened to me as well on my 2008 JD2305. Like you, removing and cleaning the solenoid resolved the issue pretty easily.
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A48081)
2000 Thomas Built...
2018 JLG 3246ES 32FT. Scissor Lift (A49346)
2018 JLG 3246ES...
1 Bridgestone 255/70R 22.5 and 1 Toyo M-872 12R 22.5 Tires (A48837)
1 Bridgestone...
2014 Dynapac CC4200 (A50397)
2014 Dynapac...
2007 Ford E-350 Cargo Van (A48081)
2007 Ford E-350...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A50505)
2018 FREIGHTLINER...
