beowulf
Veteran Member
- Joined
- Dec 31, 2003
- Messages
- 1,177
- Location
- Central California Foothills
- Tractor
- Kubota L3410 HST, J Deere riding mower
A friend asked me to help him demo his kitchen and take out all the old cabinets. I took a look at it, and was hoping all the cabinets were screwed in, but saw that the cabinets (top and bottom) were nailed to the wall/studs with large finishing nails. I decided to try to take one out - the heads were buried in the wood and there was very little room to maneuver. A real job to remove just one - they were 3 and a half inch long finishing nails - sunk into the wood and no heads to grab. It looked like we would be trying to pound a nail pull in the tight spaces, or chisel out some of the wood for each nail.
Anyway, I had a week to think about it before I went down to help him out and thought of a solution that worked. I bought a set of plug cutters at Harbor Freight - four of them in different sizes - for about $4.
Then I simply put the plug cutter over the nail heads and with the drill cut a tiny circle around each nail - going all the way through the cabinet mounting boards to the drywall. With that done, we were able to simply pull the cabinets straight out and then remove the nails easily.
This is, I know, an unusual situation, but if you do have a need to take a nail or whatever out and it appears to be difficult for some reason, and the circumstances are such that you can cut a tiny plug hole around the nail or screw, this might work out for you. It saved us a ton of work.
