Rotary Cutter A rotary cutter with lift
   / A rotary cutter with lift #1
starbrightsteve
wellsboro,PA
l2800 Kubota
I sometime move my cows into a pasture with tall grass. They eat some and flatten some. I need a new rotary cutter that will lift the flattened stuff and cut it. Are there any mowers that will do that? I don't need a cutter for firewood, I need it it cut grass!
   / A rotary cutter with lift #2
Nope,
a flail mower with scoop knives or side slicers will do that for you though.
You will need to mow at 2-4 inches in height.
You can purchase high lift lawn mower blades but a flail mower is what
you need to do this as you will have fresh growth every two weeks to
rotate pastures with fewer weeds going to seed.
   / A rotary cutter with lift #3
If you have a rear finishing mower I would check for high lift blades for it first before buying. Only issue that comes to mind with that would be if you have sandy dirt you will get a lot of sand flying and will wear out high lift blades in a hurry.
   / A rotary cutter with lift #4
Have to mow it a couple times to get it right if you use a rotary cutter.
   / A rotary cutter with lift #5
Some rotary cutters come with brush blades and some come with lift type blades , my Bush Hog Sqealer came with straight blades and left a poor cut in grass, I changed the blades to lift type blades and it made a huge difference , one other thing I did was cut some conveyor belt and put on my mower instead of chains to keep things from flying out from under it, it seemed to improve the cut even more as I believe it created almost a vacuum like a lawn mower deck does , so yes you can get a good cut and lift some of that mashed down grass with the right setup on a rotary mower.
   / A rotary cutter with lift #6
I did not know they made lift blades for a rotary cutter.
   / A rotary cutter with lift #8
Lift blades are available for my Bush Hog Squealer 720 and I had a 7' Howse brand mower that I put lift style blades on and it also made a drastic improvement in the quality of cut in grass.
   / A rotary cutter with lift #9
If the cows have packed the grass flat I doubt the hi-lift blades will help much. Yes they are an improvement over conventional brush blades.
   / A rotary cutter with lift #10
Pick up an old haybine and set the sweep reel low with the cutter bar high. Sweeps will bring up the matted grass and the cutter will slice and dice it. Set the wings for swathing instead of windrowing.
(10) 20' Continuous Fencing Panels (A50515)
(10) 20'...
2015 Chevrolet Silverado 1500 Pickup Truck (A50323)
2015 Chevrolet...
2007 Chevrolet C4500 4x4 Dump Truck, VIN # 1GBE4C3247F411826 (A51572)
2007 Chevrolet...
Land Honor Skid Steer Bale Spears (A50515)
Land Honor Skid...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2014 Nissan NV200 Cargo Van (A50323)
2014 Nissan NV200...
