BruceWard
Platinum Member
This is we added to the trailer to prevent the rear end dropping while loading. It was made from steel laying around and is yet to be painted.
They are built from 3" and 2" steel square tubing. The hanger is made from a 4" piece of the 3" tubing with one side cut off and two holes drilled through. The leg is made from a piece of the 2" tubing. A 1/4" thick 2" wide strap hinge was welded to the leg. A 1/2" bolt goes through the front hole on the hanger and the strap hinge. When the leg is vertical the top of the leg rests squarly against the inside of the hanger. The rear hole in the hanger matches up with a hole in the leg and is pinned with an additional 1/2" bolt when the leg is vertical. We made another hanger from a 2" piece of the 3" tubing and placed it at the front of the leg when it is up. An additional hole was drilled through the front hanger and leg. A 1/2" bolt with a pin through it is used to hold the leg forward when not in use. Building and installing both legs took about 2 hours.
Additional pictures online at Photo Display V1.4
