A question about washing my tractor??
   / A question about washing my tractor?? #1
Gobblin Tom
Western, PA
2011 JD 2520
I have been doing a lot of work in the woods with my new JD 2520, I have been trying to get my paths straightened out but have run into 5-6 springs along the way so things have been interesting to say the least!! Anyway I was just curious if it would hurt the tractor to use the power washer? I don't know if there is any areas that I should be careful as in electronics, etc. I really want to get the under carriage cleaned before putting the mower deck back on. Oh yeah this is one situation that I wished I had the back hoe....:(
   / A question about washing my tractor?? #2
No problem I have a 4000PSI washer not a mark on my tractors.
   / A question about washing my tractor?? #3
This is where you want to have one of the low pressure ones. I have seen real high pressure washers peel paint. I would not hold it too close.
   / A question about washing my tractor?? #4
Ha! There you go. We both answered at the same time with conflicting answers. Go figure. :)
Yeah I know you can't hold it to close..... was more worried about seals and electronics.....
   / A question about washing my tractor?? #6
you just may want to be careful around any stickers/labels.
   / A question about washing my tractor?? #7
I would just use a hose with a fairly good nozzle. A pressure washer is over kill and risky for just washing the crud off of a tractor.
   / A question about washing my tractor?? #8
A ham fisted operator can break anything....
Use a 4000 PSI washer at 1" with a 0-degree tip and you'll do damage. A 2000 psi unit at 3' with a 45 degree tip probably has less cleaning power than a garden hose.
Pressure washing is fine, if you are smart about how and where you direct the streams.
Start with a wider spray and work at a distance, if you are not getting the cleaning you need, get closer and/or narrow the pattern.
   / A question about washing my tractor?? #9
Pressure washer works great, to remove that really thick mud, just don't blow the stickers off of it, or soak the alternator or anything like that, I go easy on the dash panel also, but other wise just wash away.. Mine is 2700 lbs.. just use common sense.
James K0UA
I have a lot of clay stuck on it and I just have a spring for my hose so I don't have a lot of pressure (Has a pump though). I don't think the hose will come close to removing the clay....????
2000 JOHN DEERE 444H WHEEL LOADER (A52705)
2000 JOHN DEERE...
2025 GIYI GY-X39F Hydraulic Trencher Skid Steer Attachment (A53421)
2025 GIYI GY-X39F...
2021 TAKEUCHI TB235-2 EXCAVATOR (A52706)
2021 TAKEUCHI...
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A54313)
2019 PETERBILT 579...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
2021 JOHN DEERE 524P WHEEL LOADER (A52705)
2021 JOHN DEERE...
