A more aggressive turf tire for B-2400?
   / A more aggressive turf tire for B-2400? #1
Anonymous Poster
Epic Contributor
I am looking for someone that has had good luck with replacing a Kubota Turf tire with a more aggressive truck/mud tire. I did not want to change my 33,12.50,15 rims and hoped that a deeper tread would not throw off my 4x4 syncronization. Could someone please recommend a specific tire that I could use?
Thanks!
Thanks for your reply- Unfortunately, my dealer tells me that the tires which you have require different rims than a turf tire. Unfortunately, I don't have the bucks to buy both rims and tires! I think I did find a truck tire that will fit my current rims.
   / A more aggressive turf tire for B-2400? #4
If you have a 4x4, be mindful of the ratio between the rear tire circumference and the front tire circumference. That ratio must CLOSELY match the internal gear ratio from rear to front.
If the tire circumference ratio doesn't closely match the gear ratio, then the drive system will receive unacceptable loads which will lead to premature transmission failure. From the experience from a friend of mine with a B2100 4x4 DST, the splines on the front propeller shaft can break.
If you cannot find a set of tires that will work correctly, try cutting grooves into the existing turf tires. Cutting out some of the tread will not change the tire circumference ratio.
1 pallet of miscellaneous PPE (A53117)
1 pallet of...
2025 SDLANCH SDLD25 UNUSED Crawler Dumper (A53117)
2025 SDLANCH...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Drop Deck Equipment Trailer (A51692)
2012 Trail-Eze...
2019 PETERBILT 579 TANDEM AXLE SLEEPER TRUCK (A54607)
2019 PETERBILT 579...
2014 Ford F-150 Ext. Cab Pickup Truck (A51692)
2014 Ford F-150...
