a method of removing water from your fuel storage tank etc
   / a method of removing water from your fuel storage tank etc #1
lamanated
Nova Scotia and Zephyrhills Fl
BX2360 JD 425 jd 455
A recent conversation with a petroleum engineer resulted in me trying a way he said you can wick water off the bottom of a tank. If you take a section of disposable diaper lining, and put it in a cloth or a sock, with enough room for it to expand about 3-4 times, and suspend it via a string, down so that it lays on the tank floor, the lining will absorb the water,, The sock cant be tightly be wound, as the lining cant do its job. I tested this today and it does work,, dont let the lining material escape, it turns into a gel.
   / a method of removing water from your fuel storage tank etc #2
Look up a product I believe called Tank Snake
   / a method of removing water from your fuel storage tank etc #3
That liner can only absorb so much water, after that it's useless. It's far better to drain it off if you can.
DEWFPO
   / a method of removing water from your fuel storage tank etc #4
DEWFPO
Yep, there is a reason them tanks have a drain port.
   / a method of removing water from your fuel storage tank etc #5
+1................and some folks mount them with a slight tilt to aid in that function. Obviously the fuel needs to be dormant long enough for the molecules of fuel and water to separate.
   / a method of removing water from your fuel storage tank etc #6
Not all tanks have a low point drain, so a way to wick up any accumulated moisture is good.
I am sure a baby diaper would soak up way more water than the average tank contains which is usually just a cup full or so. If it is a super amount, just put a pump or siphon hose on it and pump it out till you get pure diesel coming out.
   / a method of removing water from your fuel storage tank etc #7
Reminds me of my Dad checking for water in the fuel of his 1947 Cessna 140 back in the 1950's. Opened the pet cock under the engine and drained a little gas out each time before startup after an extended period of inactivity.
   / a method of removing water from your fuel storage tank etc #8
I think this method could result in the diaper swelling to a point it won't come back out without squeezing some of the water out of it and back into the tank.
I use a pump attached to a tube that will reach the bottom of my tank. My backhoe had a lot of rust in the tank bottom due to it having water sit in it long term before I got it so I am mindful of this problem. I take a 12V pump with Tygon and a long metal tube and pump off the bottom of the tank every now and then. So far I haven't got any water out but I will continue to do this on occasion to make sure it doesn't accumulate any. The actual fuel pickup tube curves upwards off the bottom so it never pulls fuel from the extreme bottom of the tank.
While this is on my mind I will do both my tractors today. ;)
2005 John Deere 310G 4x4 Loader Backhoe (A53421)
2005 John Deere...
2012 Ford F-550 4x4 Versalift VO36I-01 36ft Insulated Bucket Truck (A52377)
2012 Ford F-550...
Pallet Fees (A50775)
2009 KENWORTH T6 SERIES SLEEPER (A53426)
2009 KENWORTH T6...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A52377)
2021 Allmand Bros...
