Oil & Fuel A little motor oil in the tranny
   / A little motor oil in the tranny #1
ewoz
Bronze Member
Buffalo, NY
BX2230
I am doing the 50 hour service on my BX2230. I accidentally topped off the transmission fluid with about 1/4 of a quart of synthetic engine oil instead of super UDT fluid. I plan on leaving the engine oil in there. Is there any reason that I should not?
   / A little motor oil in the tranny #2
It will be fine.
paul
   / A little motor oil in the tranny #3
I sometimes use different hydraulic cylinders used by other tractors I have and my bobcat skid steer. A little of different oils get mixed together. It doesn't matter. Don't lose any sleep over it.
   / A little motor oil in the tranny #4
If you were to hook the tractor up to a friends wood splitter,dump trailer etc your oils and his oils would mix.Wouldnt even think about it.
ALAN
   / A little motor oil in the tranny #5
He didn't mix different types of hydraulic fluid in there. He put engine oil in there. I'd guess its still no big deal. It will get diluted very quickly.
   / A little motor oil in the tranny #6
Thats nothing. I once poured about a pint of hydrochloric acid into my car engine. It was in a black plastic gallon container that looked exactly like an oil container. I'd had it outside to clean cement off some new stonework. Next day (half asleep) I went to top up the car oil and just grabbed the first black container I saw. It took me a few seconds of thinking "Gee this oil is thin" before I realised what was happening. A quick oil change followed. (The wife has never heard this story.)
HP DesignJet Z6 Pro Printer (A50325)
HP DesignJet Z6...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A52748)
John Deere 6105E...
Kinze 3500 8 Row Vac Planter (A52349)
Kinze 3500 8 Row...
2016 VOLVO VNL300 TANDEM AXLE DAY CAB (A52576)
2016 VOLVO VNL300...
John Deere 1110 Field Cultivator - Heavy-Duty Soil Finisher for Precision Tillage (A52748)
John Deere 1110...
PRESSURE WASHER GAS (A52472)
PRESSURE WASHER...
