A Flat Tire!?
   / A Flat Tire!? #1
robertm
Veteran Member
Northern Illinois
Kubota BX2660
New tractor and obviously new tires. Pulled her outta 'da barn. Front tire flat. /forums/images/graemlins/mad.gif 20 Hours on her boots. Mostly Mowing. No holes or foriegn objects found. Pumped 'er up. No leaks or loss of air in 12 hours. /forums/images/graemlins/crazy.gif What 'da !@#$%? Could I have torqued the sidewall when turning using the loader, and broke the bead enough to let a bit of air out, but then reseated the bead after straightening out the tire out of the a turn?
   / A Flat Tire!? #2
</font><font color="blue" class="small">( Could I have torqued the sidewall when turning using the loader, and broke the bead enough to let a bit of air out, but then reseated the bead after straightening out the tire out of the a turn? )</font>
Possibly, I suppose, although the only time I did that, my tire lost all its air. /forums/images/graemlins/frown.gif
   / A Flat Tire!? #3
How long had it been in the barn since the last use until the time you pulled it out and discovered the flat?
   / A Flat Tire!?
It was a few days. Now, a few days later, again, it's flat. Spent 30 minutes looking for the hole. Found it. Barely the size of a pin. It looks like a needle went through it. Darn it!
2011 KOMATSU PC56-7 EXCAVATOR (A51246)
2011 KOMATSU...
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
2019 Freightliner M2 106 Sweeper Truck, VIN # 1FVACXFC1KHKF6139 (A51572)
2019 Freightliner...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2008 Ford F-450 Cab and Chassis Truck (A51692)
2008 Ford F-450...
2003 Lincoln LS (A50324)
2003 Lincoln LS...
