thatguy
Elite Member
i got a couple questions that have been on my mind and thought this was the place to ask them..
1) I planted some kentucky 31 grass seed last fall which didnt have time to come up then. Will this seed germinate this spring or does the seed have a 'life span' once planted?
2) I am on a well and the pump is in the well casing - growing up our pump was in the basement so you could hear it cut on and off. How can I tell when the expansion tank goes bad?
3) If I was to spray a fence line with grass/weed killer.. how long before I can safely plant other plants in that area?
4) We moved in Oct from a two story 2,000 sq ft house (8' ceilings) and our average electric bill was about $106 (highest it ever went was $140, both are being adjusted for a recent rate increase to $0.077 kw/hr).. We are now in a one story 2,000 sq ft house (9' ceilings) with another 1,200 sq ft as a walk-up attic (unheated), with the attic floor being insulated as an exterior wall. Our last electric bills were $90 (Dec) $120 (jan) and $190 (feb) ..
The first house was a spec home so the insulation was code minimum at best im guessing - cheap builder.. The new house has above code insulation, not sure of spec exactly.. I realize before we had 1,000 over 1,000 feet before and now its one level for 2,000 ft. We are not leaving more lights on - but we do have a 220 pump now.
The electric bill seems to be WAY higher.. Do you think the it would increase 80% due to being single story and 9' ceilings??
Thoughts? comments?
thanks
Brian
Thoughts? comments?
thanks
Brian
