Buying Advice A Compact. What I choose and why.
   / A Compact. What I choose and why. #1
johnandcaren
As a first time tractor buyer, I found comments on this site extremely valuable. And while I make no claim my comments here are technically accurate (I'm a newbie after all), it seemed fair and respectful to repay the site with my experience.
I just bought a new toy and here are my comments for what they are worth.
Have: 7 acres in N. Arkansas. 3 are open, 4 wooded, with a fair slope in the mid section. A road needs maintaining, lots of cleaning up, etc.
Wanted: Compact, about 25-30 hp, with FEL, BB and brush hog, all 5 ft.
Originally wanted used, but was surprised at the high cost of used vs new, plus the warranty now days is just too good to pass on. I wanted my budget to be in the 10 - 12k range but quickly had reality set in, so upped that to 15 - 17k.
Reviewed: Lots of online reviews, this site and others. Really valued others direct experience. Settled on giving a serious look to:
Deere
Mahindra
Kubota
New Holland
Massey
After going to dealers, driving, etc I learned the following, some of which surprised me.
1. I was really OK with a gear unit. I thought from reading and having a zero turn mower I'd only consider hydro, but the gear is actually just fine and it saves money. If prices were equal, then I'd go HS, but with saving money the gear is fine. After 5 hours over a few days including lots of FEL work, I'm happy with the gear - SO - at least consider/drive it if your looking.
2. Deere just didn't fit me physically.
3. Kubot is clearly a high quality product, and clearly they just wanted way, way too much money. Again if money was no object, I'd probably have a Kubota but it was and I don't now. Really liked that 3300 but only the B2320 was in my range, and it only handles 4 ft implements.
4. Massey tried to sell me Kubota. When I asked why, they said Massey was just too expensive to try and sell their compacts. I guess they are really good, or whatever, but I got nowhere with Masseys.
5. Mahindra was the next to last dealer, had a great unit I loved, the 3016. Size, fit, finish, quality, all seemed up there and workable. Price was acceptable so I put on the short list. Dealer a good person also which counts.
6. Went to New Holland last as due diligence, but per phone conversations couldn't afford one. I wanted the Boomer 30. At first the salesman said I was right, it was out of my budget. Then for some reason he said " Well let me see" and started on his computer screen. Seems there was an additional promotion and all of a sudden he was the lowest price instead of the highest. Driving the Boomer 30 was the same experience as the Mahindra, but cheaper.
What did I learn?
1. Find a good dealer.
2. Try to wheel and deal them - apparently they have wiggle room once they realize you are serious.
3. Drive the units. Compare size, gear vs HS, etc.
4. Give gear a chance "IF" you are concerned with cost and it makes a difference.
5. Make a chart. I listed spec topics top to bottom, then different units across the top so I could compare lift capacities, HP, weight, size, etc.
6. Lastly, if you read this far you are probably a newbie also so Read Up On Safety. These things hurt a lot of good folks every year we don't hear about so be careful and LEARN how to be safe.
Good luck.
   / A Compact. What I choose and why. #2
Great info. So, did you end up with a Boomer?
Yes, got the Boomer.
It had 12 gears instead of the Mahindra's 8, which may not be a big deal but it was useful in choosing a bushhog speed to go since the engine is at a fixed RPM to achieve the PTO's 540 speed.
Between an easy clutch and the engine throttle it was easy to ease up on something with the FEL.
Shuttle worked very easy and quickly.
I looked under it and the castings were robust - as most are. Lines seemed well protected, etc. Engine is less accessible but no big deal.
Only thing is I picked up a 16 penny nail on day one. Can you believe a flat from a nail on the first day? A plug from the local store did fix it OK, just a "can you believe it" kind of deal.
Mostly, the dealership was large, very busy, and took time to respect my questions. Their shop was large and parts department competent.
good luck
   / A Compact. What I choose and why. #4
:thumbsup: thanks for the great article
Club Car Electric Golf Cart (A50121)
Club Car Electric...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2023 Deere 317G (A50120)
2023 Deere 317G...
Polaris Side by Side (A50324)
Polaris Side by...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
2012 RAM 5500 (A52472)
