A better mouse-pin
   / A better mouse-pin #1
LazyK
Gig Harbor, WA
JD 4200 hst
I got tired of fiddle-futzing with retainer pins with keychain type circular spring clip retainers.On the 3-point arms adjustors these loose clips and pins were a pain. There are several locations where the pins are used. I switched these pins/clips for ball-lock pins and light braided retaining wires. The wire was cut to access length, attached to pin and tractor, eliminating dropped or lost pin. After 3 years of constant use and wear I'm convinced of the benefits of this device. The convenience pays for the cost of retrofitting. I even use these ball-lock pins on the toplink connection. So far, I've never had one slip out, get lost or jam up. Just to let you-all know.
   / A better mouse-pin #2
Arthur,
You have me completley baffled. Whats a Mouse Pin and what does it look like ?
Mark...sorry for the bad take-off on...a better mouse trap...I sometimes try to stretch subtlety to a point that loses the point.
   / A better mouse-pin #4
Arthur,
I think we all have days like that. I do see in your post where you mentioned a Jack pin, how is that differant than a regular pin used for the 3ph hook up's ?
Mark...jack-pin is really the wrong definition of what I was describing. "BALL-LOCK" pin is the correct moniker. My apology to the Jack-Pin Society.
   / A better mouse-pin #7
Here is a picture. <A target="_blank" HREF=http://www.pivotpins.com/ball-lock-pin.htm>http://www.pivotpins.com/ball-lock-pin.htm</A>
Chris
   / A better mouse-pin #8
<font color=blue>keychain type circular spring clip retainers</font color=blue>
Is this one of those? <A target="_blank" HREF=http://www.pivotpins.com/catalog/lynch.shtml>http://www.pivotpins.com/catalog/lynch.shtml</A>
Chris
Best and quickest description can be foundunder... PivotPoint.com
Thanks. Next time I lend my "not-so-expert" advice to tractormen of learning and intelligent curiosity, I will have my references and follow-ups in order. Thanks again.
2008 FORD F-750XL SUPER DUTY ASPHALT DISTRIBUTOR T (A51243)
2008 FORD F-750XL...
UNUSED JCT SKID STEER QUCK ATTACH 72" BRUSH CUTTER (A51244)
UNUSED JCT SKID...
2019 GEHL RT105 SKID STEER (A51242)
2019 GEHL RT105...
BUNDLE OF GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
Skid Steer Gravel Leveler (A50515)
Skid Steer Gravel...
