9n plug wire routing
/ 9n plug wire routing #1
j250trxr
mn
New Holland 3930 4wd, Ford 8n, Sportsman 800
Distributer is numbered 1,2,3,4 so #1 should go to the cylinder by the fan, #2 should go to the next cylinder, then should #3 go by the steering wheel/last cylinder, and #4 go to the 2nd to last cylinder? I believe firing order is 1,2,4,3 from front to back. Thanks for the help Justin
/ 9n plug wire routing #2
That sounds correct. The distributors numbers run around the cap. The wires from those numbers get hooked to the plugs, as the firing order of the engine.
/ 9n plug wire routing #3
yep 1-2-4-3
3rd wire to 4th plug.. 4th wire to 3rd plug.. etc.
soundguy
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
Kubota SVL 75-2 (A60462)
Kubota SVL 75-2...
WESTENDORF 12' LANDSCAPER BOX GRADER (A63291)
WESTENDORF 12'...
2022 EZ-GO ELITE...
2016 CATERPILLAR 259D SKID STEER (A64279)
2016 CATERPILLAR...
2014 Caterpillar CB54B Articulated Vibratory Tandem Smooth Drum Roller (A61572)
2014 Caterpillar...
