9n hydraulic help!
   / 9n hydraulic help! #1
gears351
Ford 9N
ok, just got the new NAA piston assembly fit to a spare lift cover I had lying around and installed it in the tractor - I replaced the old (working/leaking) lift cover & assembly with a spare I refurbished (fresh paint & grease, cork friction disc, honed cyl NAA piston, CNH O-ring and leather backer)
Now I've got it on and the cyl leaks down when you turn the tractor off! that's without an implement on it! Push the clutch in and it'll drop with an implement... Sometimes it won't come down unless you shut the tractor off. It bucks and twitches most of the time it's up if the throttle's low.
I'm thinking it's the control valve on the pump.... or is it the safety valve?
Twitching means I need to tighten up the freshly painted draft spring right?
I've yanked the cover and there's no leakage from the cyl or at the lift cover gaskets - no oil spurting out a cracked transfer tube... I don't see swirling in the sump other than the yolks pumping.
Ideas, advice?
   / 9n hydraulic help! #2
check valve, relief, etc.
could be control..e tc.
twitching can also be leak and regen..
2011 Land Rover Range Rover Sport AWD SUV (A51694)
2011 Land Rover...
2012 John Deere 7230R (A53473)
2012 John Deere...
2013 FORD F450 XL SUPER DUTY BUCKET TRUCK (A51406)
2013 FORD F450 XL...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
2013 Ford Taurus AWD Sedan (A51694)
2013 Ford Taurus...
Brown & Sharpe Fitted Spindle (A53117)
Brown & Sharpe...
