990 Rear Hydraulic Couplers/Power Beyond
   / 990 Rear Hydraulic Couplers/Power Beyond #1
ejb17
Bronze Member
Western NY
JD 650, 4520
Been using the 990 snowblowing this winter for about 8 hours but it is now hopefully time to think spring and get ready for cleanup. I need to add rear couplers for my 12 foot woods mower and power beyond for the soon to be 4 n 1 bucket. The two kits from JD can get the job done but can I mount both on the back of the tractor without them interfering with each other? I am going to use an electric over hydraulic valve and push button handle for the 4 n1 extra functions. Also any good leads on Galaxy tires so I do not have to buy new rims when I change to turf for the summer?
   / 990 Rear Hydraulic Couplers/Power Beyond #2
Hmm... your post is a bit confusing. It's not altogether clear, exactly what you're planning to do with the hydraulics on your 990.
I recall that JD offers the power-beyond circuit for the 990 as well as the optional rear mounting for the mid-mount SCV's.
It is my understanding that you can have both at the rear of the tractor without a mounting conflict.
However, if you are planning on using the electo-hydraulic (Fasse valve, etc.) switch --- why bother with the PB circuit at all?
I'm probably missing something in the equation --- so, maybe somebody like kennyd can pipe in here to make things easy to understand...
You might come across a used pair of rims to mount your new R3's on but I wouldn't hold my breath...
When I was shopping for tires/rims I found some at dealer's around the country here: Used Farm Equipment & Agricultural Equipment - John Deere MachineFinder.com
And eBay...
Best of luck.
AKfish
   / 990 Rear Hydraulic Couplers/Power Beyond #3
I have a set of turff tires and wheels i think would fit your tractor if you are interestes.
Akfish, I was wondering about how to have the rear PB and the electric hydraulic valve both and you mentioned exactly what I was thinking. Maybe I could put quik couplers on the elec/hyd in/out ports and use those for the PB when using the woodsplitter etc. Was definitley wondering how to do all this. You bring up a great point. The rear SCV couplers seem straight forward and was just worried about mounting conflicts as the 990 does not have a lot of room on the back. Garry-let me know what you have size wise on those wheels and tires as turf size for the 990 is 27x12.5x15 fronts and 44x18x20 rears. I asked about Galaxy tires as they seem to be the only ones who make turfs the same size as my r-4's. Thanks
2013 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400LB Crane Service Truck (A53422)
2013 Ford F-550...
Hydraulic Hose Reel (A52377)
Hydraulic Hose...
2020 FORD F-350 FLATBED DUALLY (A55745)
2020 FORD F-350...
Komatsu PC360LC (A47477)
Komatsu PC360LC...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A55302)
Michelin CARGOXBIB...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
