$99 Lesson - 3pt Hitch Will Not Go Down
   / $99 Lesson - 3pt Hitch Will Not Go Down #1
SanDucerro
Yoakum, TX
Kubota M7040 - L3130 - ZD326S
Thought I'd post up my experiences today in an attempt to save someone a service call...
While drilling holes with the L3130 today, the 3pt hitch brought the Post Hole Digger up out of the hole - but then it wouldn't go back down again. It was literally frozen in the UP position! Which - of course - is far better than being froze DOWN in the last hole we drilled. We looked at the linkage, worked the lever, checked everything we could think of - but nothing seemed amiss. Everything on the tractor was working fine - except for the 3pt. Even the FEL, which suggested the issue was something other than hydraulic.
We took the tractor back to the house, unhooked the PHD - and rechecked everything again. Still no luck - and unfortunately, we were under a time constraint and time is money - so I made a call to my local dealer. They had a service rep out on a call not far from us and were able to stop by within the hour. The tech had a trailer to haul the L3130 back in to the dealer if he couldn't find the issue - but fortunately the issue was something extremely simple. Turns out there is a dial that is directly below the seat that controls the 3pt hitch hydraulics and the dial had been rotated to lock the 3pt hitch. I hate to admit that in my 10 years of owning this tractor I had never even noticed the dial. I did read my owners manual when I bought the tractor and even invested in the Service Manual. I've changed the oil and filters, I've fixed a no-start situation with the HST pedal switch, I've replaced the battery, I've replaced the headlight - in general, I can find my way around a tool chest when needed - and perhaps that was the problem. I was obviously looking too hard for a serious issue.
At any rate, it took the tech less than 15 minutes (if that long), to get us back in business and give us a lesson in how to work that dial! :ashamed: Near as I can figure, my pant leg must have caught the dial when I moved to get off the tractor and check something we were doing.
Props go out to Victoria Oliver Kubota's Hallettsville shop. They were FAST, efficient, and knowledgeable! Total price to share this knowledge? $99 - and worth every penny... :2cents:
The moral of my tale would normally be to read your manual, but as I mentioned - I had already done that. Perhaps a better piece of advise is to periodically reread your manual! It's easy to overlook something after 10 years!
   / $99 Lesson - 3pt Hitch Will Not Go Down #2
I use that when I switch between heavy vs light implements. I will even reach down and quicken the drop if I am going over real uneven ground with the box scraper so that it reacts quickly with the contour. Otherwise I make it a safe gentle speed for lowering. Glad you are "fixed" but sorry it cost you time and money.
   / $99 Lesson - 3pt Hitch Will Not Go Down #3
Another word of advice is to lube and rotate the control at least once a month, had the one on the BX rust up once.
David Kb7uns
   / $99 Lesson - 3pt Hitch Will Not Go Down #4
thanks for the post...I'd forgotten about that dial, and didn't know it could lock in the up position, or rust up...good info, sorry you lost time and money...
   / $99 Lesson - 3pt Hitch Will Not Go Down #5
Raised the front mowing deck on my Kubota F3080 yesterday while mowing and it wouldn't come back down. Took almost a minute to remember the dial behind the seat that a slight turn lets the lifting/dropping return to normal. The first time I did it or found out about it is when I called Barlows and talked to Gary and told him my deck wouldn't go down after working properly for several weeks and he told me to turn the knob.:D
I to had one freeze up on a BX that was under the front of the seat and actually broke the plastic knob trying to get it to turn.
Pallet of 7' LED Lights (A56469)
Pallet of 7' LED...
2019 Deere 550K (A53317)
2019 Deere 550K...
2018 Ford Fusion (A56859)
2018 Ford Fusion...
UNUSED FUTURE 44" EXCAVATOR RAKE (A57193)
UNUSED FUTURE 44"...
JOHN DEERE 5075E LOT NUMBER 30 (A53084)
JOHN DEERE 5075E...
2016 Chevrolet Silverado 2500 HD 4x4 Pickup Truck (A55973)
2016 Chevrolet...
