9600 Ford fuel leak
/ 9600 Ford fuel leak #1
jhp123
VA
1965 ford 5000 2000 new holland 1920 4wd, 1974 ford 5000, 1975 ford 9600, 1988 case Ih 885
I have a 1975 9600 with six cylinder diesel. Fuel is coming out of the fuel injector on the side up against the motor. I can't see exactly where it's coming from. it doesn't leak while idling, but it begins to leak in a small stream coming from the engine side of the pump when the engine is revved up. what's the most likely problem?
/ 9600 Ford fuel leak #2
could be return line, injector line or injector
/ 9600 Ford fuel leak #3
I'm a bit confused. Is it leaking at the injector or the injection pump?
Sorry dt86, i can see where i wasn't clear. It is NOT leaking out of the injector lines coming off the pump or the injectors. It appears to be leaking from the side of the injector pump that you can't see.(engine side). Could not get a good visual on it. Was hoping to get an idea before i tried to take the pump off, of what is on that side that would leak with a steady rate once throttle is increased from idle. thank you for the help:)
2009 Caterpillar 345D Hydraulic Excavator (A64553)
2009 Caterpillar...
NEW Landhonor LHR-AIW1  1" Air Impact Wrench  (A62679)
NEW Landhonor...
1 Bottom Subsoiler (A65640)
1 Bottom Subsoiler...
KUBOTA KX080-4S2 EXCAVATOR (A64277)
KUBOTA KX080-4S2...
Wolverine Brush Cutter BC-13-72W Skid Steer Mount  (A62679)
Wolverine Brush...
60 Traffic Cones (A65579)
60 Traffic Cones...
