955 loader/blower info
/ 955 loader/blower info #1
torch
I need to know if any of you have a 955 with a 70a loader and a front mount 59 snowblower. Is it hard to change from one to the other?? Torch
/ 955 loader/blower info #2
Torch,
It is a breeze to switch from loader to snowblower and vice versa. Removal of the loader takes 1-2 minutes. Then you install a quick-tach bracket under the front end (2 bolts), install the drive shaft from the mid PTO to the front bracket, drive into the snowblower arms, connect them, and finally connect the 4 color-coded hydraulic hoses. The snowblower takes maybe 6-7 minutes. It is about the same amount of time to remove the snowblower and install the loader.
JackIL
thanks for the info, its much appreciated!!
