95 Ford dually wheels
   / 95 Ford dually wheels #1
Newblue
Central Indiana
New Holland TC45DA SS
We picked up a 95 Ford cab chassis dually for my wife and it did not come with a spare tire. I was given a 235/85r16 for a spare so I need a wheel now. The wheels takes flat lug wheel with a pin that I guess locates the wheel on the hub. From what I have been reading there are three offsets for Ford dually wheels but no mention of the hole in the wheels for the pin. The truck is a 95 2x4 cab chassis with a 460 gasser. When I start going to yards I wonder what wheel I should ne looking for?
   / 95 Ford dually wheels #2
Actually had this saved. From where I don't know.
Ford 84-97 F-350 dual rear wheel (Production from 01/85 - for trucks built 12/84 and prior use 8-6.5" pattern, 4.75" bore, stud centered). For 85-97 F-350/450/Superduty dual rear wheel use 8-6.5" bolt pattern, 4.88" bore and are hub centered.
Check offset using a straight edge across the outside of your existing wheels and the measure to the center
Thanks for the info. Is the pin thing a cab chassis only deal or is it all ford duallys of that era? The roll pin sits between two of the lugs. Looks like my offset choices are: 5.00", 5.15", and 5.35"
   / 95 Ford dually wheels #4
It's been a long time since I sold the truck, but I believe the pin is on a plate between the dual wheels. I'm not much help because I really can't remember. Mine was not a cab and chassis truck if that helps. Not sure what the pin is for other than to hold the plate in place.
It has a roll pin sticking out of both the front and rear hubs. The rear one goes from the hub through both wheels in the back. I need to tack a pic.
Thanks for the help,
Mike
I think I found a pic. Hard to see but the pin is on the upper right of the hub.
2012 Audi Q5 AWD SUV (A51694)
2012 Audi Q5 AWD...
Genie GTH-5519 (A50123)
Genie GTH-5519...
2006 Chevrolet Express 2500 Cargo Van (A51692)
2006 Chevrolet...
2025 K2010 UNUSED Chicken Coop (A53117)
2025 K2010 UNUSED...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2025 Mower King SSECAG-Y (A50123)
2025 Mower King...
