93 cat 426 or 96 cat 416
   / 93 cat 426 or 96 cat 416 #1
spo307
Levittown & Long Eddy NY
kubota L4400
I have a choice between a 93 cat 426 4x4 extenda hoe 4500 hours, 4in1 front, 12" 24" waynes wright bucket, 36" bucket, or a 96 416 4x4 no 4in 1 bucket, extenda hoe, any suggestions thanks,
   / 93 cat 426 or 96 cat 416 #2
My father has a 95 Cat 416, 4x4, x hoe and it has been a great machine. I think there is only about 4K hours on it, but it has been super reliable and strong. Only two things that we have had consistant trouble with:
-The X hoe cylinder leaks all the time. We have rebuilt it twice and had a Cat replacement and the replacement's packings let go just recently.
-The fuel filter set-up is a glass bowl with many small gaskets that always appears air tight, but some how gets air-bound. Its only a problem when starting cold and trying to run it too hard too quickly. A quick few pumps on the primer and she's good to go for the rest of the day. Can't seem to figure it out, but its been like this for at least 5 years and she still runs great.
I'd kick the tires on both to see which was better taken care of. 3rd party buckets for these aren't to expensive, but doing pins and bushings is. You didn't mention the hrs or any attachements on the 416. As far as I know the 426 only gives you a little more digging depth.
   / 93 cat 426 or 96 cat 416 #3
The general contractor I work for uses Cat hoes exclusively now after a long history with Case. We've had each of the 2 models you're looking at. Both are very capable machines IF they're in decent shape.
Unless you REALLY need it, the X-tenda hoe is more of a nuisence that it's worth. They leak as mentioned and make the hoe heavy and awkward when using the front loader. Both are old enough to be worn out. I'd take a look at the condition of each and let that be my determining factor with a tie breaker the newer one withOUT the X-tenda hoe.
Avoid any hoe that's spent time with a hoe ram attached.
2024 Bintelli ActivEV Pulse Electric Golf Cart (A51694)
2024 Bintelli...
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
YOKOHAMA - GALAXY 16.9-24 DIAMOND BUTTON TIRES (A53472)
YOKOHAMA - GALAXY...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A53472)
2021 John Deere...
UNUSED AGT TSOCPF48 MAST W/ 48" FORKS (A51248)
UNUSED AGT...
