SacandagaBrad
Platinum Member
The top nut on the left side spindle on my 60" side discharge deck keeps loosening slightly. I can tell by the "rattling" sound that develops while mowing. The drive pulley can be rocked/wobbled side to side by hand, and there is play between the blade and pulley indicating the key is loose. I can tighten it down and all is smooth and quiet, there is no binding or grinding like a bearing is going even when turning it by hand. I can mow for about an hour before it starts making noise again. I do not have a torque wrench handy.
Am I to the point of needing to apply some LocTite or do you think I am on my way to putting a new set of bearings on that side?
Mower and tractor are 8 years old, tractor has 750 hours and I mow about 1.5 acres from late April thru October around here. It has always been well lubed.
I'm leaning toward giving the LocTite a try first for obvious reasons, just wondering if anybody else has experienced these symptoms.
Thanks - Brad
Thanks - Brad
