Mowing 914A MMM Mower Fell Off
   / 914A MMM Mower Fell Off #1
jwstewar
Elite Member
South Central Ohio
Kubota L3301
Was doing a little bit of puttering around yesterday when I backed up to my little 2 wheel trailer that had some remaining sand/gravel from the poles on the garage. Got off the tractor and started to hook the trailer up to the tractor, but I needed to back the tractor up about 2 or 3 inches more. I went back around put one foot on the deck as a step (does anyone else use it as a step?) about that time, crash!!!!!! Guess it is time I lose some weight /forums/images/graemlins/blush.gif. Since the mower deck was pinned up I knew this wasn't good. I looked underneath the tractor and the plate that the deck is attached has (well had) 4 bolts in it. I found one of them with the threads all messed. I had also found one about 2 weeks ago, but didn't know where it went. I called the dealer they were going to pick it up this week, but since the tractor was pretty much unmovable I found the right bolts, cleaned the threads up on the tractor and put new bolts, lockwashers, & lock-tight on them and tightened them down good. I'll also put them on my list of things to check when I grease and so should you. Just glad I wasn't mowing when it doesn't to come lose. What could've been a bad situation turned out OK, I'll call the dealer tomorrow and tell them not to bother.
   / 914A MMM Mower Fell Off #2
jwstewar
I found a bolt on top of my mower deck one day. Searched around and found the same problem you had. The remaining three were loose. I measured and the tapped holes would take a longer bolt, so I went to the hdwe. store and got longer bolts/lockwashers and put on blue Loctite and no more problems.
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
2020 Kia Sportage LX SUV (A50324)
2020 Kia Sportage...
2019 Ford F-350 XL (A50120)
2019 Ford F-350 XL...
2017 Chevrolet Express 2500 Cargo Van (A50323)
2017 Chevrolet...
John Deere No. 5 Sickle Bar Mower (A50515)
John Deere No. 5...
Skid Steer Plate Attachment (A50322)
Skid Steer Plate...
