911 help with Pallet forks for JD2520
   / 911 help with Pallet forks for JD2520 #1
PLUMBER
Bronze Member
Fairfield county , CT.
JD 2520
I have a set of heavy duty pallet forks that are the fork lift type with fixed forks not the landscaper type that float it is designed to work with skidsteer type quick tach im wondering is there a adapter from a 200CX loader to the forks i have or can i buy the parts to have welded on my fork set up so i can use the JD quick connect on the 200 CX need to know asap have to unload a truck in a couple of weeks thanks for your help in advance
   / 911 help with Pallet forks for JD2520 #2
Plumber,
Deere does make and sell the top curled portion that mounts to your loader as well as the pins for the bottom. I have bought some to make an adaptor for a snow plow. The total cost was about 35 bucks.I don't remember the part numbers. Maybe someone else on the site may have the part numbers.
2024 ArmorLite Aluminum End Dump Trailer (A56438)
2024 ArmorLite...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58214)
2011 NORAM POWER...
Unused 2025 CFG Industrial XZ20R Mini Excavator (A59228)
Unused 2025 CFG...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A59823)
2018 GENIE...
Kubota M6 131 HP
Kubota M6 131 HP
2018 John Deere 1653 (A56438)
2018 John Deere...
