8N
   / 8N #1
farmerdean
NW missouri
1947 ford 8n
got a problem with my 8n. seems to be fuel problem. starts fine. idles fine. won't rev up unless i close the choke halfway or more. rebuilt carb this fall. been running fine since then. checked inlet screen, removed carb & checked float setting, i use quality gas with seafoam in it. any ideas?
   / 8N #2
Needing choke to run is a classic symptom of:
1. Restricted fuel supply - Pull drain on bottom of carb, should have steady flow for at least a minute.
2. Weak spark - Plug should be blue/white with gap opened up to 3/16"
3. Vacuum leak - With engine running, spray WD-40 around intake/block mating area; carb throttle shaft and carb to manifold connection. If engine speeds up, you've found a vacuum leak.
   / 8N #3
yep.. and needing choke to throttle up deffinately makes me think lean.. either from restriction or leak...
UNKNOWN 16 T/A TRASH TRAILER (A53843)
UNKNOWN 16 T/A...
2016 Nissan Altima 2.5 Sedan (A54815)
2016 Nissan Altima...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
Chevrolet Tahoe SUV (A52377)
Chevrolet Tahoe...
2009 Honda Pilot AWD SUV (A53424)
2009 Honda Pilot...
