rhouyoux
new member from central VA
now that I'm retired I'd like to learn to fix my 8N whenever there is a problem; for quite a while I have a low battery problem, I just connected my Chevy to start it, but now it refuse to start, I replace the points (adjusted the gap), cleaned the spark plugs, but still no spark (none at the points, and of course, none at the spark plugs).
What is wrong?
I'd like to follow a tutorial/guidelines to explain to me what I need to check, I'm not an electrical engineer but I can check the voltage of my battery with a voltmeter...
I was told that I need to check the coil, but:
1. I'm not sure how to remove the cover, there are 4 bolts on the dash board, and 2 more right over the front axle, do I remove them all, then lift the whole cover?
2. what are the checks to perform on the coil?
3. other checks I should do?
Thanks in advance,
Richard
What is wrong?
Thanks in advance,
Richard
